Question about Sony STR-DE835 Receiver
Instruction for 5 channel input on Sony STR-DE835
I cannot find the manual that came with my receiver and I need instruction on how to connect speakers and subwoofer for 5 channel input. Would greatly appreciate any advice.
    Problem Solver:
  • 41 Answers
I found the operating instructions here:
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDE835
Posted on Dec 06, 2008
No sound on coax audio input from HDTV
Check your settings on your tv. You may have to turn off the internal tv speakers in the setup menu in order to get any audio output from the jacks on the back.
Dec 20, 2012 | Sony STR-DE835 Receiver
Just received a Sony Receiver STR-K650 with a sony video DVD recorder SLV D300P WITH NO MANUEL OR INSTRUCTIONS ON HOW TO HOOKUP THE TWO SYSTEMS AND PLAY iT.NEED HELP?
STR-K650:
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRK650P&LOC=3#/manualsTab
SLV-D300P
http://esupport.sony.com/US/perl/model-home.pl?mdl=SLVD300P&LOC=3#/manualsTab
The above links will give you the instruction manuals and the connection guides.
Sep 07, 2011 | Sony STR-K650P
STR-DE835. White noise coming ferom right rear speaker when DVDs are played. Twise the word "PROTECT" has been displayed.
IF any other source plays fine with the RR speaker, and IF it only happens with the DVD player and IF you're using the 5.1 analog audio feeds to the STR, maybe the audio on that channel is **** from the player. You could prove that by temporarily swapping the RR input from the DVD to any other channel input and test it at a medium level.
If it stays with the DVD RR output, the player or the cable would be suspect. Swap in a different cable and make sure it is not routed uniquely near any sources of magnetic fields, motors, UV or track lights, etc.
If you're using digital input all that advice was a waste of time to create as there is nothing external to the chipset that could affect one input channel. Try a different digital input on the STR.
Jan 30, 2011 | Sony STR-DE835 Receiver
The receiver will be on for a while 5mins.or so, then it will make this loud sound as it goes into protector mode...what is this and how do I fix this. I have it connected to the TV, DVD Player, CD, VHS...
you have speaker wires that are shorting out. unhook all the wires and ohm them out. Find out which one is shorting. I've had this problem before. It's fine until you turn it up, Then the receiver turns off and goes into protect mode. It's just a short in the wiring,.
Dec 08, 2010 | Sony STR-DE835 Receiver
Sound clicks off Sony STR-DE835 5.1 Channel
THIS UNIT HAS BAD SOLDER CONNECTIONS ON REGULATOR TRANSISTORS,REMOVE BOTTOM AND YOU WILL SEE THE BAD CONNECTIONS.ALSO BE SURE TO RE-TIGHTEN ALL CHASSIC GRD SCREWS AS THIS WILL ALSO CAUSE THE SAME PROBLEM.
Apr 14, 2010 | Sony STR-DE835 Receiver
STR -DE835 no sound
Theres a couple of problems you may have. 1 bad solder connections,you can remove bottom plate and look for bad connections and 2 you may have shorted transistors, however if the protect relay comes on its probly bad connections.
Apr 06, 2010 | Sony STR-DE835 Receiver
Sony STR-DE835 5.1 Channel Receiver When looking at the Sony Service Manual Supplement-1 There are several modifications to receiver does anyone know the reasons for these Mods?
THIS IS NOT A MODIFACTION ,ITS AND ADDITION TO THE ORGINAL SERVICE MANUAL WHERE THEY LEFT OUT THESE PARTS ON THE ORGINAL SERVICE MANUAL.
Dec 04, 2009 | Sony STR-DE835 Receiver
My STR-DE835 receiver will not stay powered on
Most likely bad output transistors and a couple of resistors. mp1620 and mn2488 are the part #s for the transistors. If you take it to a repair shop you are looking at spending $100-$130
Nov 16, 2009 | Sony STR-DE835 Receiver
Sony STR DE835 center channel issues.
it could be your wire. try using different speaker wire. if it still has that same problem, take the cover off and tap on the amplifier.
Mar 01, 2009 | Sony STR-DE835 Receiver
Hook up problems
either cut an rca cable and splice it to the speaker wires (not easy because the rca cable is coax type or buy rca ends from radio shack and do a little soldering
Jan 02, 2008 | Sony STR-DE835 Receiver
Sony STR-DE835 Receiver Logo
263 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
