Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Amana fridge out
Nopower to fridge,lights inside does not even light up,power to outlet
  • mlt3d1 Dec 06, 2008
    plugged in a blow dryer it worked checked all cords no damage.
    the light bulbs are not burnt out or loose, i took them out and tested them, they light up in a lamp, so, what else could be wrong, love trouble shooting. ha,ha,
    Scholar:
  • 82 Answers
Hello
How do you know if the outlet is ok? Did you try plugging something else into it? You need to make sure that you plug it into the same one and not the one above or below it. Also sometimes the outlet won't have the full 110-120 volts needed to run something. Is it possible that you have had a mouse problem? Mice love to chew on wires and take out appliances. Let me know what happens.
Posted on Dec 06, 2008
  • Shane Hays Dec 06, 2008
    Hmm. Are you sure the bulb is good? Sometimes the bulb will be bad and a child may have turned of the frig making it seem like there is no power. I've gone out on a call like that. If you think the bulb is ok then you will need to call for service.
  • Shane Hays Dec 07, 2008
    Well it sounds like you need to call for service. The only time I have seen this happen in my 17 years of doing this, is when there is damaged wiring somewhere, but there is always an exception to the rule which could be in this case. Note: you may have a loose connector in your frig somewhere that has come loose. This would require taking all of the inside and outside panels off to try and find it. Some rare instances I have seen wires in the freezer walls short out and that is when it is time to get a new frig. Again you should probably call for service. Sorry I couldn't be more helpful.
Has no power inside no dash lights 1995 nissan 240 sx
check the fuses under the hood I seen this exact same thing happen to a friends 95 Honda prelude and it blew a fuse
hope this helps
Aug 30, 2014 | 1995 Nissan 240SX
No power even to light inside refrigerator
Check the fuse in the plug to the fridge and replace only with the same type and values. Unplug and check the cable for signs of damage.
Apr 05, 2014 | Refrigerators
Compressor wont start up fan in freezer stays on
        • Pull the fridge out from the wall and check to make sure it is plugged in.
        • Unplug the fridge and plug in a spare appliance to see if the outlet is working. Check the circuit breaker to the house see If the outlet is not working to see if there are any fuses that are flipped.Inspect the electrical cord for the refrigerator for damage, such as from a mouse or pet chewing on it.
    • Open the fridge to see if the light turns on. The power to the unit is fine if the light turns on, which means something else is the cause of the starting issue.
    • Turn up the thermostat on the inside of the fridge if it is set to a low setting. Turn it all the way up and listen for the condenser motor to start. Have the unit serviced by a professional if it does not May be internal problem with component
Dec 13, 2013 | Freezers
No power to refrigator check plq and it is hot Light in sisde dont even work
It could be a loose connection where the power cord is connected to the refrigerator inside or a bad power cord. If that doesn't solve the problem you may consider calling a repair person.
Good Luck,
GilShultz
Mar 01, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerator has lost power no eletric to inside light, not cooling not freezing
First , check if is power in the outlet where the fridge is plugged in by plugging something you know works (table light , radio,etc.) , if it doesn't work , means there's not power at the outlet what could be a trpped breaker , burnt fuse , burnt or loose wire at the outlet, or a bad outlet ; but if you got power in the outlet , probably the fridge cord or its plug are bad.
Oct 15, 2009 | Whirlpool Refrigerators
No light, sound nor green button
maybe a lizard is die inside and shock your power supply circuit
Jul 01, 2009 | RCA 36F530T 36" TV
1993 Jeep Grand Cherokee Laredo Break Light Sensor
check the brake switch located on a bracket under your driver side, on top of the brake pedel check for power, if power depress on your pedal see if there's nopower on the other side of the switch then replace the switch. I think it is the switch.
Mar 08, 2009 | 1993 Jeep Grand Cherokee
Samsung fridge freezer no power 2 unit
Most of the time when not even the light comes on and there is power to the outlet it's just a simple matter of replacing the cord. good luck
Dec 16, 2008 | Freezers
If your light inside does not light when you open the door you problem could be power related. Your description sounds as a power supply problem. Try moving the power cord to another outlet.
Apr 29, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge problem
You may have a short some where in the fridge. If you have a multimeter, I would suggest metering the power leads to the compressor. The compressor may be bad, if you find no shorts in the metering of the power leads.
Jan 10, 2008 | GE GBS22HCP Bottom Freezer Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
63 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
