Question about Sony Mavica MVC-CD400 Digital Camera
CD 400 Power on button will hardly move
Just recently the button (for lack of a better word) is almost to the point where it will not move, this includes turning it on, or moving it from S-A-M Camera, set up etc. I have looked in a few different forums, but I haven't come across this problem. Does anyone know what I should do? Thank you
    President:
  • 4,402 Answers
The switch is going bad send it in for repair
Posted on Jan 08, 2008
I have a sony 400 cd player and the lights come on, but the carousel won't move. When I press any button the button will light up but nothing happens. The blue light flashes all the time. Also, the door...
sounds like your loading mechanism is jammed up. I would take the cover off, and look in the back where the cd's load to play and see if you can see anything out of place.
Dec 04, 2013 | Sony CDP-CX400 400-Disc CD Changer
Losuing over drive lack of power hard starting must hold pedal to the floor
Does it start better after sitting overnight? Is it missing at all? Check engine light? Hard starting could be fuel pump, also lack of power could be lack of fuel. If it starts better after sitting overnight, could be block catalytic converter. That would also explain lack of power. If you have to hold gas pedal half way down trying to get speed would explain why it is not going into overdrive. Hope this gives you some direction.
Jan 04, 2012 | 1996 Chevrolet C1500
I have an ATI radeon X1300 Low Profile 256mg PCIe graphic card for my Dell Optplex 620 (SFF) computer. I'm wondering about the power draw. The computer has only a 240 watt power supply. Will this tax...
Your computer should be able to handle the graphics card with no problem.
The only issue that comes up is how many hard drives or CD Rom drives are attached to the system.
If everything is stock out-of-the-box, you are OK.
I hope that this helps.
asnowman
Mar 05, 2011 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
My Dell E1505 Laptop won't start. When I hit the power button, I get 3 green lights, a short beep, and it sounds like the hard drive is starting to spin up, then it shuts off. I have tried several things,...
CPU and RAM do not have any moving parts so it is very unlikely that they would fail. Just make sure that you reseated them properly and move on.
The most likely point of failure on any computer is the hard drive.
Insert your Windows CD/DVD and attempt to boot to it. This will bypass the hard drive.
If your computer boots to the CD/DVD and allows you to select options then the problem is the hard drive and you should replace it ASAP!
If it does not boot to the CD/DVD you should try replacing your AC adapter or motherboard. Look on eBay for the best pricing on replacement parts.
I hope this helps. Good luck!
Oct 21, 2010 | Dell Inspiron E1505 Notebook
I recently moved and when i hooked all of it back
open it up check all the connections memory and add in cards for security.
connect it and try again. Sometimes the bios battery can cause wierd problems, they are usually a 2032 battery on the motherboard. replace it if it's suspect. I would then look at the power supply. Big heavy capitors don't like being dropped, (neither do hard drives for that matter).
Jan 10, 2010 | Dell Dimension 8200 PC Desktop
My brother in law asked me to help with his hp dv6000. I have a system mechanic I was going to try on it. The problem is that the computer will not turn on. You can push the power button and all of the...
Assuming it's a desktop pc not a laptop the power supply might be faulty. Try and replace it. If the computer has being recently moved, you will need to open it up and see if all connections are on. Also if that doesn't work, try and disconnect all the cables to your cd roms and hard drives and see if that works. More than likely the power is shot and you will need to replace, should cost between $30-$80 to replace. Make sure you look for a 500watt power supply as they work better if running multiply drives.
Aug 10, 2008 | HP Computers & Internet
I have a brand new 2008 Alpha H3 Hummer...it hesitates off the line, bogs down and just won't hardly go sometimes, other times it rocks, runs great. It also tends to run a little hot, and I think I notice...
I have the same problem. Been back and forth with the dealer and GM. Everyone knows this is a problem but Hummer will not reprogram the computer. It was suggested to me to get a vortex to adjust the computer shift points but the unit is $400 and will void your warranty. Sucks big time
Jul 28, 2008 | Hummer H3 Cars & Trucks
Sony Mavica MVC-CD400 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
