Question about Acer Aspire 1800 Notebook
Acer 1800 problem!!
I have an Acer Aspire 1800.
the problem is following:
after switching on the power button it is switching off automatically.
I have checked the memory, but with no success.
How can I fix it?
thanx
optimus
  • 2 more comments
  • optimus2007 Dec 06, 2008
    I ave tried it, but no success : (
  • Anonymous Dec 07, 2008
    there is no hard disk in it.I think it is a hardware problem
    and not a software one.
  • optimus2007 Dec 07, 2008
  • Anonymous Dec 19, 2008
    YEah, same thing here, switching on the machine gives a sound as if the hdd is spinning real fast, and the hdd led comes up and stays on untill the damn things shuts down completely :(
    removing hdd wont work, same for the memory, battery, dvd
The Aspire 1800 suffers heat problems
Are the fans located on the anderside working ? are teh three vents on the back expelling air . id s this stream hot or warm?
I had an 1800 that had collected a blanket of fur and dust on the heat sink fins, it switched off during boot. Removal and cleaning fixed the problem. Remove the heat sink cover (bottom, rear, 4 screws) Remove the heat sink (4 spring tenshoned screws) loosen and replace them in the numbered order (1,2,3,4) do not disturb or touch the special grease on the heat sink and top of cpu, do not allow dust or dirt to contaminate these greasy surfaces. Yo can remove fur, dust, with a small wet brush or just rinse it away with fresh water allow to dry and replace all. good luck
Onsitepc
Posted on Feb 07, 2009
  • 88 Answers
Try this when you push the power button down to turn it on, hold it for 3 to 4 sec. then let go hope this helps . biigg53566
Posted on Dec 06, 2008
  • Alan Matzke
    Alan Matzke Dec 06, 2008
    what windows are you running?
Off switch
a broken power switch is unlikely...more often than not the problem is the power supply, this can be checked by following this procedure - http://www.overclock.net/t/96712/how-to-jump-start-a-power-supply-psu-test-a-power-supply-and-components
Oct 05, 2013 | Acer Aspire M1641-U1521A PC Desktop
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Acer cannot switch on to wifi
I have that same one bought new and the wifi card was bad when i bought it
Jun 30, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
On my acer aspire one laptop ,when i press power button on ,it light green for 2 second then it switch off automatically.no display on screen ,it remains black
try to replace the memory chip. if you have an extra memory chip, replace it and just make sure its a working memory chip.
Jul 11, 2011 | Acer Aspire One PC Notebook
Acer Aspire 1800 No Boot. No Power
CONTACT ACER EXPLAIN PROBLEM AND SEE IF THEY CAN RESOLVE THE PROBLEM.HOPE YOU GOT A WARRANTY.
Nov 30, 2009 | Acer Aspire 1800 Notebook
Acer Aspire 1800 Won't boot
I recently had Acer Aspire One Laptop with very similar symptoms: No screen, no lights (those that indicates activities) except Power button. I first thought the Hard Disk is dead but it's not.
I contacted Acer helpdesk in Australia and they have sent me a document with BIOS update and instructions. I did what it says and then the laptop is back to normal. Yours may have the same issue - need BIOS update. The Aspire One BIOS update requires a FAT USB drive with the updated BIOS and the BIOS Flash program, plugged it in, press and hold 2 buttons: Fn and Esc, then press Power button for a while.
You should seek Acer Support website. But you may need proof of purchase.
May 09, 2009 | Acer Aspire 1800 Notebook
Function F6 works only sometimes to blackout screen on acer aspire 5315
I just came here looking for a solution to the same problem. I have an Aspire 1800 which has a front panel of buttons for the Arcade mode. Basically i just wiped all the buttons again resonably vigiously as i was pissed off and low and behold the FnF6 works again. I tried this after i read another artical suggesting the removal of the touchpad driver. so obviously something is still depressed much like a sticky key which basically switches the screen immediatly back on as i had a flicker at least when i did FnF6. Hope this helps..
Oct 22, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 1800 Notebook Logo
311 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
