Question about Cobra 148 GTL 120-Channels Base CB Radio
Trying to hookup echo board
I cant find the auido wire from mic to board
    Problem Solver:
  • 13 Answers
Just look up cobra 148 mike wiring diagrams and see which pin on the mike is audio then look where that pin hole goes in on the mike socket in the cb then solder your audiowire to that spot on the inside part of your mike socket
Posted on Dec 30, 2008
    Problem Solver:
  • 9 Answers
Take it to the cb shop it requires some soldering skills and time
Posted on Dec 06, 2008
I need a schematic for a LT2 echo board to install in my president grant PC-409AB
break audio line. J2 input goes to mic pin J1output to radio.
(leave the shielded ground wires disconnected. on audio)
Power use a 1k ohm resistor from 12v dc on pwr switch.
Ground run the ground wire to board ground
test and set echo level.
this will work for any radio. if the echo needs 12v instead of 8v remove the 1k resistor and just use a 1n4001 diode on the power wires . some models require 12v some are 5-8volts.
Jan 18, 2015 | Radio Communications
Logitech G930 Echo problem
Check the device manager for duplicate devices and make sure that the on board devices are disabled
Dec 09, 2013 | Logitech G930 Wireless Headset
Feedback problems with astatic echo boards
This is a classic indication of a lost shield or ground connection in the mic circuitry. Double check these connections for good contact in the mic *and* the plug at the other end of the cable.
Check the grounding and SWR or "match"of the antenna system, too. A poor SWR (greater than 1.5:1 or 2.0:1) can cause the reflection of RF back to the radio. Modifications can increase sensitivity of the mic to this unwanted RF.
Sep 29, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Looking to install astatic echo board in uniden PC78XL
usally on most radios you will unplug the wire that comes from the number two mic plug. you will hook you sheid witch is the 2 little black wires from the echo board to number one mic plug. then the two wires will go to wire you unplug and the other one will go to number 2 mic plug.
Jul 04, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
How to wire a power echo mic up theres 5 wires and 4 oins
I suggest buying a 5 pin to 4 pin adapter. Ebay has them for $6. I would go chopping wires on the mic. Cobra 29 ltd is a nice radio. Have one myself.
Apr 25, 2009 | Cobra 29 LTD CB Radio
I cant hear
Hi
Go to the control panel, click on the sound icon, click on the recording tab, make sure your Mic is the default and there is a tick beside it.
Good Luck
Mar 28, 2009 | Acer Audio Players & Recorders
Trying to wire up a atatic echo board in a cobra
Take the mic plug apart and look at it the wire with the shield around it is the audio, then look and see which pin it hooks to.
Feb 21, 2009 | Cobra 29 LTD CB Radio
Cobra 200
Hello Jim. These radios do not work well with any power mic including the power echo mics because they have good modulation boards in them. But if you still want to try then check http://www.cbtricks.com/radios/cobra/200gtl_dx/index.htm
Mar 26, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
220 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
