Question about Philips LX3600D System
Wont work I have a Philips LX 3600 D home cinema system and the last time i tried to switch it on it refused to do so. No life whatsoever in it. Any suggestions.
  • 2 more comments
  • Anonymous Feb 24, 2008
    gaat niet aan of uit powerstandbylampje blijft rood knipperen wat nu????
  • Anonymous Dec 11, 2008
    YO NO CONSIGO PONER EN MARCHA LA RADIO,NI EL DVD NI NADA.EL PILOTO ESTá EN ROJO,,,,,,
  • Anonymous Mar 31, 2009
    There is no power on the player, unable to power up. Occasionally, it might power up for a second then the red light disappears.
  • Anonymous May 15, 2009
    same here it was freezing in the middle of a dvd, then one day it just would not power on at all
  • 3 Answers
Check front PCB
Posted on Oct 30, 2007
  • Vashkar Chatterjee
    Vashkar Chatterjee Oct 30, 2007
    Also check the Power supply unit inside. It would be good to take it to a Philips Home care.
My philips hts3520/94 not working, the power button blinks maybe 3 times white and then stays white ....it alawys happens when trying to power it up...i tried to unplug the power for almost 24 hrs and
That trick usually works. Suggest you ask Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Dec 11, 2014 | Philips HTS3520/05 5.1 ch Home Cinema...
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
Philips home cinema dvd wont eject
If you bought it with a credit card you should have up to 90 days to return it. You will void the warranty if you try my solution. look on the back and sides. There should be some small screws. Take them out and then slide the back off of the player. You should be able to see the disk tray. Some systems have a manual eject button hidden somewhere inside. Once it is open you should be able to find the model number of the dvd drive. Look up the specs and see if you can find the button. Otherwise you can try to force it open. Be extremely careful if you do this. You could strip the gears and or break it. If the gears are exposed use a small flat head screw driver and slowly turn the gears till it opens. I hope this helps.
Dec 28, 2013 | Philips Audio Players & Recorders
Would like unlock code for Philips HTS5593 Blu ray
To make your Philips BDP3100 region free (this works on a BDP3100/05 purchesed in the UK in June2010)
1. Make sure there is no disc in the tray when you switch on.
2. Press "home" key on remote control.
3. Enter number "1389310".
4. Switch off. Wait a few seconds and then switch on...now region free.
Please note, the above hack has only been confirmed as providing region-free DVD, not Blu-Ray.
Mar 14, 2013 | Philips HTS5593/12 3D Home cinema system...
Hi all, I have a Philips Lx 3600 Dvd HTS and the DVD is not working. I would like to replace it, but it is also the builtin amplifier for the 5.1 system. Is it possible to buy another DVD/amplifier that is...
I have the same issue but it looks like buy a cheap philips DVD 5.1 with the EASY CONNECTORS and link to your existing speaker set. The new speakers can act as a fall back to your existing set.
Jul 20, 2011 | Philips LX3600D System
When I turn on my Philips lx8500w dvd player my wireless internet stops working, what may be the problem?
the lx8500w uses the same frequency as the wireless (2,4Ghz). I bought the same system, it's ********. Just problems and after 2 years it doesn't work anymore (goes to standby after 1 hour or so). Try to change the wireless channel. Or buy another home cinema...
Mar 19, 2010 | Philips Home Cinema system DivX LX8500...
Dear sir, i have Lx 3600 Dvd home theatre system & now only the dvd player is not working,now from where i can get only dvd player,or any other solution.I tried from phiilips dealer but nothing in my...
I have the same problem. However you can't abandon the system since the player has an inbuilt 5.1 channel amplifier. I have been told by someone that I can use another DVD player and connect AV chord to LX3600 D which will be used as amplifier only.
Mar 29, 2009 | Philips LX3600D System
HTS 3300 - No Disk Error
i had the same ploblem sometime last year and all i did was to put a cleaning disk(the ones with a cleaning brush on) in it a couple of times...and it works fine since then!
Aug 07, 2008 | Philips HTS3500S System
Lx 9000r wont play any dvds even previously played
You can try reseting the unit.
Reset the set to the default factory settings:
All the information stored
(programmes, time and date) will be lost.
1.
Disconnect the set from power supply.
2. Press and hold down "STANDBY•ON" on the set and reconnect the set.
3. As soon as "IS TV ON?" is displayed, release "STANDBY•ON."
Hopefully reseting it will clear whatever problem it is having and allow you to once again use your DVD player.
Hope this helps. Good Luck.
Jan 22, 2008 | Philips LX9000R System
37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Nov 29, 2007 | Philips 37PF7531D/10 37 in. LCD Television
Philips LX3600D System Logo
254 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
