Question about Uniden BC92XLT Handheld Scanner
Im replaceing a bad audio socket in my scanner and need help
The old audio socket i unsoldered is a 4 pin and i cant find a new one so i am trying to install one thats a 3 pin from radio shack. Wondering how to do that and make it work.
Thanks in advance,
Dennis Stewart
  • 120 Answers
Im guessing the 4 wire jack is for stereo, and that scanner has the fm broadcast band, a three wire jack is for mono.
Posted on Jan 10, 2009
My karcher window vac does not seem to charge?
Have you tried to take it all apart just a small bit of rubbish will stop it from working.
Jul 24, 2014 | Karcher WV50 Window Vacuum
My canon hv30 wont show up on my pc. i got a firewire but its not showing that its plugged in
Does your Inspiron have a Firewire socket? (my Inspiron 1720 has a 4 pin F/wire), If so try a F/wire to F/wire lead instead of F/wire to USB.
There are three sizes of F/wire socket, 4 pin, 6 pin and 9 pin which can be bought in any combination of the three.
Good luck.
Dec 30, 2011 | Canon VIXIA HV30 DV Camcorder
I have a akai ea a7 graphic equalizer deck, its pretty old but has a digital display, but the display seems to have gone very dim, its working perfectly and admire its build quality but i really wanna get...
you need a new fluorescent display unit.... i also have one of these graphics. (mine was occilating on the frquencies set higher than mid level)
the part you need is: IND FL BG-205ZK (Akai part No EM-349875).
if you're fixing it yourself, best to snip the old one off the board each leg at a time near the glass, then unsolder the long pins left on the board (the longer the pins, easier to grab with pliers when unsoldering)..... you'll have a very hard time trying unsolder the lot in one go and probably end up burning the tracks off the board, a desolder pump might help if you want to do it the hard way.
Feb 02, 2010 | Audio Players & Recorders
The center pin of the external power supply jack is broken off. Is there some place who repairs scanners ?
your second option is to re route the track so by solder 2 wires to the original power input and routing them to the ear phone socket make sure to disconnect the wirering from the ear socket first ,on your power supply unit remove the jack and replace with ear phone jack makes sure to put positive to centre and other to ground earth
Jan 14, 2010 | Radio Shack Pro-94 Scanner
OLD 4 CHANNEL SCANNER. CAN'T GET SIGNAL. NO
go to Radio shack and they can help you with it.
here in Nebraska they Quit transmitting on lower freqs and moved way up on the radio band.so it made the old scanners wothless.you can still get weather but no police.fire calls.
Aug 12, 2009 | Radio Shack Pro-97 Handheld Scanner
Finding information to aid replacing cpu cooler
Yes, some do come with push pins like that instead of screws so that it is easily removed and installed also. Usually the push pin ones are cheaper. The cpu and heat sink are compatible by cpu socket type.
Apr 04, 2009 | Fujitsu Siemens Computers & Internet
Mic socket is not working
hi im josh in cebu phils. may i help you? friend if the problem is your mic socket is not working. try buy a new sound card then put it in the pci slot. it will give you new sockets for audio, mic.etc.at the same time it will give you better audio performance. good luck.
Feb 20, 2009 | Intel D845GVSR Motherboard
No Audio
Most likely it pulled hard enough to cause some bad solder connections on the botton of the 4 pin...try to unsolder and resolder the connector and reconnect the speakers this should fix you up.
Feb 05, 2008 | Sanyo DS27590 TV
HP 5470c - No power
I've done it, using an adjustable power supply all i needed was 12VDC - 2Amp, the power connector going to the scanner is a 4 pin mini-DIN male, so i've ripped of the cable from the original bad power module, cable has inside 2 wires one black one white and a shielding. Black and schielding are connected together and are going to the minus, the white one is going to +12V
guess what? .... my scanner is working again
Nov 25, 2007 | HP Scanjet 5470c Flatbed Scanner
Uniden BC92XLT Handheld Scanner Logo
51 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
