SOURCE: Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
SOURCE: Inspiron 6400 detects networks but does not connect to internet
Make sure you are connecting to your own internet connection through your wireless router and not on your neighbor's.....limited connectivity means you are out of reach or signal is blocked....
SOURCE: Dell laptop with wireless card unable to connect to network
The specs for the Dell Inspiron 6000 with the Intel PRO/Wireless card
are list as 802.11b or 802.11g while the router you bought uses 802.11n.
Your best bet at this point would be to either return the linksys
router and get an 802.11g model which is slower than 802.11n, but will
be supported by your laptop. Or you can buy a 802.11n wireless adapter
for your laptop to connect to your new router. Either way the rules of
wireless are you need your device and router to be speaking the same
wireless standard. So, pick 802.11n or 802.11g and stick with that
standard for your gear.
SOURCE: On Dell Inspiron 1501, at college dorm, wireless internet drops
Hmmmm
If you can obtain an "802.11 N" wireless card, a USB type then you may have better luck maintaining your connection.
In the meantime, set your card to use "Only G", not "B" or "A".
This will keep your connection at the highest speed until you invest in a "N" adapter ($30).
Hope this helps!
Testimonial: "Thank you - hope it's easy as you make it sound!"
SOURCE: My wireless on my Dell Inspiron Mini 10 has never
Your Dell may not have the wireless card driver installed.
Install the latest wireless driver.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
To setup your wireless router and the wireless card in the Dell, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
