Question about Toshiba SD-V392 DVD Player/VCR
No color on playback
My dvd vcr combo no longer plays DVDs or VHS's in color. Television color is excellent, but no color when using playback. Have red/white/yellow connector cables for audio/video and they seem to be connected in the right places.
  • 537 Answers
SOURCE: just got this dvd/vcr combo
Please look at the following link for a manual:
Posted on Dec 02, 2008
  • 88 Answers
SOURCE: install s-video cable now dvd is black & white
you might have a bad cable just because you get a great picture but no color.i would exchange the cable where you bought it and try another one.
Posted on Dec 06, 2008
SOURCE: progressive scan
I had the same problem once and the solution is to reboot the DVD player. to do this you need to unplug the unit for 3 or more minutes and then you will have to go through the setup process again but everything should work fine and interlaced (not progressive) should be the dvd format again.
Posted on Feb 14, 2009
  • 197 Answers
SOURCE: Playback Problem
open the recorder, 4 screws at each corner, wipe the playing head and the voice reccognition head, to the right of the playing head head with a baby wipe, you will be amiazed what **** comes off it. DON'T scrub it just wipe lightly, spin the playing head so it's clean. If you have a lint free cloth ( a glasses cleaning cloth you get in the case is brilliant) Try the tape (before you put it in make sure everything is DRY!) and your problem should be solved. It worked for me! and that came from a TV engineer
Posted on Jul 15, 2009
SOURCE: If I videotaped an HBO or Starz movie onto a vhs
yes because there is no incription code
Posted on Sep 05, 2009
  • 6993 Answers
SOURCE: Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Posted on Apr 28, 2010
0 characters
1 Points
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | DVD & Blu-Ray Players
I have a Toshiba DVD/VCR combo and I want to know if i can record a VHS onto a blank DVD disc ?
It all depends on the model of DVD/VCR Combo and what VHS you want to copy.
Pre Recorded VHS are copyright protected so the system won't let you copy them.
May 29, 2011 | Toshiba DVD & Blu-Ray Players
The manual for my DVD-V3500 says that you can't record from DVD to the VCR. But, can you record from the VCR to a DVD?
In short, no. Not with this unit on its own. No function for recording from or copying to DVDs exists with this brand/model.
A separate DVD recorder is required. I don't know of anyone who records DVDs to tape these days.
You are correct; the manual states clearly you cannot record from the DVD deck in this machine, which is a bit unusual, considering other brands of combos such as LG, SONY and PANASONIC offered an input (which was between channels or could be selected via remote) to allow DVD to VHS recording within the one unit.
I would presume you can connect this combo to the input of a DVD recorder, play a videotape and it will work via cables. DVDs last longer than tapes anyway.
Feb 03, 2011 | Samsung DVD-V3500 DVD Player/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
My Sony DVD/VCR combo will play cds but not dvds. I took the top of the player off and I can see that the dvd spins but it won't play. It used to play everything very well but just stopped working...
Please clean laser lens with good quality cotton bud gently and check dvd disc playback, if still does not play, replace optical lens block.
Let me know model number of your Sony DVD-VCR combo to provide you optical laser block part number info.
Nov 15, 2009 | Zenith DVP615 Portable DVD Player
How to repair Panasonic VCR Combo PV-D4742 which flutters at playback. DVD unit works fine.
your videoplayer(vhs) heads are dirty, use a vhs cleaning tape, buy from your local music store, or ask them where to get one, or your the videotapes you are using are worn, try other newer less used tapes if they work fine then the tapes your trying to play are worn, otherwise dirty play heads are the problem.
Jul 01, 2009 | Emerson EWD2203 DVD Player/VCR
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The insigina combo
i would check the tv TO DVD/VHS COMBO connections OR REPLACE OLD AUDIO VIDEO CABLES especially if the tv plays clearly.
Dec 11, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Toshiba SD-V392 DVD Player/VCR Logo
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
