Question about Seicor Fiber Optic Cable
Fiber cable running through a steam tunnel
I need a fiber cable that will withstand heat such as a steam leak in the manhole the cable runs through.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
    Problem Solver:
  • 17 Answers
Well, ahaaa, why not search optic fiber cable online??? I just know Shenzhen has many optic fiber products manufactureres. They always supply the comeptitive price. Jusk like www.ingellen.com . Go ahead and find something that you need. If you have any questions, just hit the live chat to ask them. Hope my sharing can helps you out!!!!!
Posted on Dec 17, 2011
  • 449 Answers
Use UTP cable to replace a fiber cable
Posted on Dec 12, 2008
My monster steam booster wont heat up.1200 watts
it wont heat that much.thats just the maxium wattage it can withstand
Oct 25, 2014 | Vacuums
What are fiber-optic leak detectors?
These are leak detectors that fiber-optic cables that run the full length of the pipes that you want to check for leaks. They work by measuring the changes in temperature of the cable when it comes into contact with the substance that is in the pipe. This gives you a really acurate reading of where the leaks are.
Oct 13, 2013 | Measuring Tools & Sensors
Steam leaking from the under carriage
It could be due to the coolant pipe and hoses that go to the back if you have rear heat. If steaming, leaking and running hot I recommend that you don't drive the vehicle until the problem can be repaired or damage to the engine could occur.
Feb 16, 2013 | 2002 Kia Sedona
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
The temp gauge reads correctly for a while then it starts going from cool to hot faster the water can change temp. I have changed the sensor
try the thermostat, located on the top radiator hose. top side of engine. also does it steam?? does it lose water but no leak, does the heat blow hot? if your heat isnt hot and it steams and loses water you may have a cracked head or head gasket. if you have heat, doesnt lose water and doesnt steam it may also be your water pump. most pumps will leak visibly from the weep hole when running
Aug 02, 2011 | 1999 Dodge Caravan
I own a 1999 Ford Expediton and the heat nor ac is working, plus all the coolant is running out of vehicle, there is a hole in the steel hose coming from the coolant system up front, and also top where it...
this steel hose is a coolant line for the rear heat so it will be under pressure, the fix you do has to withstand this pressure so i would have it fixed properly and replace the line. Is this why heat doesnt work as the coolant leaks out?
Feb 06, 2011 | 1999 Ford Expedition
My iron rowenta leaks when before and after i!m iroeing
my iron is different to yours but i used to have leaks as well.
for me it was because i have a heat setting dial that indicates that the steam function is activated when set to a very high temperature.
i also have a push lever on the top of the iron that controls how much, if any, steam is produced by the iron.
the amount of steam is regulated by letting more or less water through to be vaporised by the heating element.
if the heat setting is low and the steam setting has not been switched off then water is being allowed through but the element is not hot enough to vaporise the water. the result is water pooling and either dribbling through onto the clothing you are ironing or running off when you sit the iron up.
maybe it will help if you turn the steam setting off while the iron is not in use.
Jan 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Steam is coming in car through heating vents
this would be a bad heater core. this is located under the dash on right side inside the heater box next to the blower motor the steam is acctualy radiator fluid that runs through it.
Jan 02, 2010 | 1991 Buick Park Avenue
I got something on the bottom of my rowenta steam iron. How do I remove this? Can I use an SOS or brillo pad?
I would not use that type scrubbing pad. It will probably get steel fibers in the steam ports -- if you don't get them all out you could get rust on your clothes.
Try a stiff fiber scrubbing pad -- non-metallic. If you use soap, check to see if the steam ports need cleaning of whatever soap may have gotten in them.
And then maybe run some steam though the iron -- like steam iron an old rag to clean it up before actually putting the iron on good clothes.
May 09, 2009 | Rowenta Professional DX8900 Iron
Computers & Internet Logo
194 people viewed this question
Top Seicor Computers & Internet Experts
David Payne
David Payne
Are you a Seicor Computer and Internet Expert? Answer questions, earn points and help others
