Question about Samsung TV Remote Control
I found this samsung lcd in the trash and the red light comes on
But when i used a a unversial remote it didnt work and the the codes didnt work i needs help it works i jus cant get it on what do i do
  • ajunja Dec 06, 2008
    well how much will it cost to fix it
    Genius:
  • 2,920 Answers
Take it to a shop and have them fix whats wrong with it. just because a light comes on dosent mean the tv works . take it to a shop man
Posted on Dec 06, 2008
  • Ronnie Houston Dec 06, 2008
    probably a couple hundred but if u found it then it ought to be worth that much to fix it
Unversial remote code for nb530mgx
Purchase a good universal remote (Philips comes to mind) and use code search. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Nov 14, 2016 | Magnavox Televison & Video
How do i program a vibe unversial remote for apex digital converter box
Use the code search feature to find something that can handle some or all functions of your Apex STB. If a search through all codes contained in the Vibe remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jan 13, 2016 | Televison & Video
I have the onn unversial remote model # 12AVO58 i need codes for funai dvd blu ray player
If your remote is universal, it probably has a code search feature you can use to find a suitable code for your Funai player. If a search through all codes stored in the remote fails, you may have to try another universal remote.
Feb 06, 2015 | Funai Televison & Video
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
After a power outage my dynex tv stopped working...the red power light wont even come on...is the tv repairable or is it trash?
Mine did the same thing. Unplug the basterd and wait about 30 minutes. Unplug all auxilleries connected to it too. Then plug it in again. The red light should come on. The problem is that the liquid crystal power supply got switched off during the outage. If that doesnt work then you have to check the motherboard section 5V. If it is off you should see a number 1. If its on you should see a number 0. Thats what the schematic drawing shows. I found this in the online manual for troubleshooting dynex flat tvs. Fortunately I didnt have to touch the motherboard. I'm not telling you to go inside the tv and get yourself killed. Think safety at all times if you must go inside. Find the manual too. I dont remember where I found it, but you should be able to find one.
Jul 21, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
But curtis lcdvd320a with no remote can"t get universal to work
I am having the same proplem for Curtis lcd3717a. I tried a RCA unversial romote crcr350. Can not get to work. Any universal romote that would work with this TV
Dec 11, 2009 | Curtis CMMT32 32 in. LCD TV
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
BOUGHT SAMSUNG LE40A656 LCD CAN,T GET SKY REMOTE TO WORK
I tried the closest model no. in the Sky list in the system setup, I think the code was 0840. Cover the front of the remote and press TV, then press red & select button until the remote led light blinks twice, key in the code 0840 and then press select.  Try the volume button and this should work.  If you get stuck go into interactive and system setup and select setup of sky remote and it gives you a list of makes and models, this is the closed one to the LE40A656 and works with mine.
Hope this works for you.
Jan 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Configuring Sky remote
3. Press tv again
Samsung Code: 0060
Sep 20, 2008 | Samsung AH5900092W Remote Control
Samsung TV Remote Control Logo
121 people viewed this question
Jerry Greenberg
Jerry Greenberg
