Question about Emerson MW8102SS 1100 Watts Microwave Oven
I have a fix for Emerson microwave model MW8201SS re: keyboard / no cook problem.
I am an Electrician w/ stong electro-mechanical repair skills. I was recenly given an Emerson microwave oven (model #: MW8201SS)where the keyboard only partially worked and when the start button was depressed, nothing would happen. Upon disassembly of the unit I found 1). worn keyboard ribbon cable contacts, as well as 2). Door safety interlock switches (there are 3 on this model)that were out of alignment. After cleaning the contacts on the ribbon cable and slicing about 1mm off the end of the ribbon cable and realigning the microswitches in the interlock mechanism with the white nylon interlock actuator tabs, I was able to get the thing to work (yeah!!). Warning: Under NO circumstances shoud you EVER cheat the safety interlock safety switch assy. It is there for your protection.
  • Emerson Master
  • 9,156 Answers
Good job. Careful is trhe watchword.
Posted on Oct 22, 2007
SOURCE:
Can I disable the express quick cook feature of Emerson MW8997B?
That feature may or may not be on your microwave oven. GE has quick cook options of 30 and 60 seconds (not a keypad selection).
Aug 15, 2018 | Emerson Microwave Ovens
How do I set the clock on Emerson microwave model mwg9111sl
Hello!
Here is the link to the manual for Emerson MWG9111SL - setting the clock.
I hope it will help!
Microwave Cooking Emerson MWG9111SL 8 23
Jun 19, 2017 | Emerson Microwave Ovens
How do I fix my microwave oven?
At auctions microwave ovens sell for about $10. Can;t repair much for $10 so why bother. Just go to auction or garage sale..
Jul 11, 2015 | Emerson Microwave Ovens
How do I correct a microwave that runs automatically with a display when connected to power outlet but does not heat up anything. The kitchen timer,clock and all other buttons works except express coo
Check and replace magnitron with one of the same number or equivalent.High tension transformer fuse may be blown or high voltage diode and or capacitor shorted. N.B. Please disconnect applance from mains and discharge large capacitor before carrying any DIY on any microwave,
Nov 07, 2014 | Emerson Microwave Ovens
My emerson microwave grill/combo microwave won't cook anymore how do I i fix it?or do I just need to just replace it?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jun 21, 2010 | Emerson Black Microwave Oven
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Emerson MW8102SS 1100 Watts Microwave Oven Logo
219 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
