Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Gas oven that cooks unevenly
I have a frigidaire gas oven that cooks unevenly. It burns cookies on one side of the cookie sheet. Any ideas? It is only 3 years old and cost about 500 bucks.
Thanks - John
  • jmagnant Dec 06, 2008
    My stove is only 2 years old and the orifices dont look bad, but I will clean them. It is a NG stove, but came with an attatchment so it could be used with propane. Is this unsafe?
    Thanks for your help !!
  • Anonymous Mar 21, 2014
    cooks hotter in bottom of oven
    New Friend:
  • 57 Answers
No, if it came with something to make it work on propane, that's fine, just make sure it's adjusted properly...otherwise you'll get a lot of sooting, and orange flames instead of blue.
Posted on Dec 06, 2008
    New Friend:
  • 57 Answers
Clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Why does my new stove, bought Feb. 2014, have a problem cooking my meats or cookies?
Read your user manual about settings and rack placement.
Also check to see if you upper oven coil is working.
Ask your appliance maker or appliance repair shop.
Did you get a warranty for your oven?
Nov 30, 2015 | Ovens
How do i fix an oven that bakes unevenly
the cooking I can't help with, but the oven I can.
sounds to me like the bottom element or what controls it is not working. the reason the ones on top are cooking is that the top element is coming on and browning them on top after the heat has made the dow rise and cook.
so essentially everything is cooking from the top down. so when the temp drops its using the top element to heat with and thus browns the top rack.
check ur elements to make sure both work, if so, move on to the thermostat which I have to be the culprit many times.
Feb 26, 2015 | Ovens
Oven burns in back and raw in front
That oven is very poorly rated and is prone to a lot of repairs. Most people advise to get something else. There is no common solution. I am sorry.
Feb 15, 2013 | GE Profile JTP56 Electric Double Oven
Fan is not turning
yes if you ave is set for fan forced...no if you have is set for non fan force....a lot of ovens have many setting depending what you are cooking....top oven/bottom oven or fan oven plus a combination.
Jul 24, 2010 | Frigidaire FEB30S5D Electric Single Oven
My baxter rotating tray oven is not baking cookies evenly. The cookies on the outside of the cookie sheet are over-done and the cookies in the middle of the cookie sheet are not done ??
Inside your oven you have an array of louvers or fins in the back left corner and the front right corner. Sometimes a tray will jam and knock one of the louvers out of adjustment. You may need to call a local authorized service provider to come and reset your louvers to the factory settings. In the meantime you can attempt to make small adjustments to see if you can rectify the issue.
Do not ever adjust the louvers in the back left corner of the oven.
For the trays in question, to direct more air towards the center of the cookie sheet slightly bend the louvers in the front right backwards towards the rear of the oven. ONLY MAKE SLIGHT ADJUSTMENTS!! If you bend the louvers too far you will end up burning the center of the cookie sheet and under cooking the edges.
Jun 14, 2010 | Baxter OV300E Stainless Steel Electric...
Temp cycle span from on to off is 32 and 33 degrees respectvly
Obviously the thermostat calibration is out, most manufactures allow a tolerance of + or- 10%, so yours is outside this range.
You can compensate by setting the temperature lower by say 20 degrees, this will then bring it within accepted tolerances.
Hope this helps you.
Dec 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Jul 24, 2009 | Amana AEW3530DD Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
297 people viewed this question
Top Frigidaire Ovens Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
