Question about Daewoo L700C 17" Flat Panel LCD Monitor
IBM LCD Screen turn deem
I am fixing an IBM LCD Screen, running winXP, computer will boot up for 10 secs, and turn into Blackscreen,(very deem,if you look closely you can see.) I have noticed that, when boots up, LCD turn little red colour, I don't know the screen is too old or what!? or the mother board is bad, and also the little switch connect the mother board and the LCD display is build in with the mother board, therefore i could not change that! D'oh...
    Novelist:
  • 159 Answers
If my research effort is accurate, _dim_ LCD screens are typically caused by problems with:
-- The inverter
-- The backlight
-- The screen itself.
Apparently it tends to be a pick-and-chose effort to diagnose the problem.
I'm not quite sure you mean that the LCD display is built in with the motehrboard ... are you sure you don't mean the video card, or is this an all-in-one product?
At any rate, you may get some tips here:
http://repair4laptop.org/
They almost certainly will not have your exact model of computer/laptop/screen/whatever it is you're trying to fix, but you may be able to look at other products and see what's involved in changing parts. If it really is an LCD _monitor_ that's bad, depending on your technical expertise, patience, mechanical aptitude, available money, and such, you may just want to replace it. Or try a few parts ...
Posted on Dec 05, 2008
How do I fix black screen on my Dell desktop?
I have downloaded Software <---------- did you download or did you install?
the computer became black screen? <----------
Terry
Feb 19, 2015 | Dell Computers & Internet
Samsung sens g25
Reinstall your video driver just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
Check for registry issues
Start the computer in safe mode and run System Restore
If this didn't help you then simply get the Intel software partner reliable program "RegInOut" to fix these errors which causing black screen.
Thanks
Jun 13, 2013 | Computers & Internet
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
BSOD when turning compuer on c0000021a
You need winxp bootable disk for format or repair your winxp.
Then boot your computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then set first boot device in bot option as your cd or dvd rom.Then save settings .
Then put your disk in rom then it boot with it.
Aug 01, 2009 | IBM ThinkPad R51 Notebook
The computer will not boot to OS
Hi jsc,
It sounds like your internal video card which is used to display information to the LCD is defective. I would recommend taking it in to a hardware shop to have them take a look, and if it is under warranty still, to send it back to the manufacturer for them to fix.
Thanks and please take a second to rate!
Mar 20, 2009 | IBM ThinkPad T40 2373 Notebook
IBM Laptop A2629 LCD Problem
sounds like your video is going out wheather its your card or lcd not sure but kinda sounds like the screen
Dec 24, 2008 | IBM ThinkPad A20 2629 Notebook
Formtting my hard drive
if you are formatting your computer for the first time and if you bought your computer after 2005 then just press <Ctrl> + <F11> keys right at the dell logo on startup, you will boot to dell PC restore. This will restore your computer back to the factory settings including WinXP, all the drivers and softwares.
If you bought your computer before oct 2005: then follow these steps.
1) start you computer and at the dell splash logo tap <Del> key to enter setup. (restart and retry till you see entering setup)
2) select Boot from the tabs above using arrow keys.
3) select boot device priority press <ENTER>.
4) select ATAPI CDROM, <ENTER>.
5). insert WIN XP CD in the top drive of the computer and press <F10> select yes.(this will restart your computer).
6) after reboot you will see " press any key to boot from CD" press any key within 5 sec on this message.
7) Press <ENTER> to install
8) Press <F8> on next screen
9) Press <ESC> on next screen(Options may vary on this screen , read instructions).
10) select partition using arrow keys press <ENTER>
11) select NTFS/NTFS quick, anyone. and press F on the next screen...
this wil start WIn XP set up and concludes the formatting of the HDD with Win XP CD.
Apr 28, 2008 | Dell Dimension 4500 PC Desktop
System restore
Specifying the Default Operating System for Startup loadTOCNode(2, 'summary'); If you have more than one operating system on your computer, you can set the operating system that you want to use as the default one for when you start your computer: • Click Start, click Control Panel, and then double-click System. • On the Advanced tab, under Startup and Recovery, click Settings. • Under System startup, in the Default operating system list, click the operating system that you want to start when you turn on or restart your computer. • Select the Display list of operating systems for check box, and then type the number of seconds for which you want the list displayed before the default operating system starts automatically.
To manually edit the boot options file, click Edit. Microsoft strongly recommends that you do not modify the boot options file (Boot.ini), because doing so may render your computer unusable.
Feb 19, 2008 | IBM ThinkPad R31 2656 Notebook
Daewoo L700C 17" Flat Panel LCD Monitor Logo
145 people viewed this question
Top Daewoo Computers & Internet Experts
John Anderson
John Anderson
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
