Question about Philips Magnavox 20MT133S 20" TV
Philips wide screen 32in Digital TV
My tv when switched on, no pictures but light-blue screen appears with white lines running accross the screen from top to bottom. There is sound though.I can listen to the TV like a radio. It started a few weeks ago with the pictures being cloudy and light-blueish. A few days ago i could switch it off and on then the coulor would return but it would keep turning 'cloudy'for a few minutes the ok for another half hour or so Any one have idea of what is going on? thanks
    Novelist:
    Champion:
  • 236 Answers
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Posted on Feb 17, 2007
SOURCE:
No picture, no menu, black screen, no raster, sound ok
From your detailed description, it sounds that the main chroma processor IC has damaged. Raster means nothing, but the lighted screen that appears, when a TV is switched ON. For some brands, there will be a blue screen; when there is no signal input, and some others will have a bright white screen with some snow.
I advice you to contact any service technician, to get this TV repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 07, 2014 | Televison & Video
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
White line accross screen holds when picture goes up and down.
This can be caused by the contrast being set too high. Typically, for a Sky box the TV's contrast should be set to around 65.
If this does not help, then the LCD panel is probably at fault.
Apr 25, 2009 | Philips 32PF5531D 32 in. LCD Television
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
Blue Line on
Your problem is simple. The problem is your pannel. You need a new one. If it is under warranty, have it fixed. If not buy a new tv.
Mar 14, 2008 | Televison & Video
Blue screen
no sounds on tv
Feb 25, 2008 | JVC AV-27260 27" TV
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
White line horizontially through middle of picture
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Oct 25, 2006 | Bush 5693D 24" TV
Philips Magnavox 20MT133S 20" TV Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
