Question about Canon PC-940 Black and White Copier
The ink cartridge in my Canon - PCII is stuck.
The copier cartridge is stuck and I cannot remove it. Also I'm
getting black streaks all over my copies. I know nothing about
copiers but the streaks seem to match the roller inside the
cartridge.
How can I get the cartridge out without ruining the copier?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Put off your copier. kindly look at the side where your paper exit , u see an opener, this will open the copier. then draw the cartridge
Posted on Dec 06, 2008
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Cannon D1150 I have a crease down the middle of the page as well as faint black ink. How do I correct this. this happens on envelopes as well.
this sounds to me as toner cartridge fault.
Remove the crg and look at drum surface for streaks. If the streaks are on drum surface, replace drum ( toner ) cartridge if not the problem is in fixing assy.
Hope that helps!
Aug 23, 2011 | Canon imageCLASS D1150 All-In-One Laser...
Our mp530 is giving error code 6a00. I have swabbed ink out of the pad area that the ink cartridge docks and it appears that the pad has gotten stuck in the down position. It will not pop back up in spite...
Hi
The excess ink is dragged across the printed paper and smears the page with streaks of ink.
The excess ink dries fast and cloggs the printhead.
The black ink on the color ink printhead can contaiminate the other colors and ruin the print quality.
To resolve these 3 problem, try to replace the ink cartridges.
If not, try to remove and reinstall the wiper blade back in place. You will need to take the printer apart and take out the purge unit and re-install the wiper blade. If the blade is broken, you will need a new purge unit.
Post comments for more help
Mar 22, 2011 | Canon Office Equipment & Supplies
It is leaving a black streak on underside of page
That's odd for an InkJet printer to do that, but try swapping for a different ink cartridge as a test. Also, check the rollers, maybe some ink got on them. If that's the case, it should dry up eventually (soon).
Apr 05, 2010 | Canon Pixma iP4500 InkJet Printer
Thick black streak down the back of whatever i print with my canon pixma MP 500 printer
The spray nozzle on the ink cartridge is probably clogged. Take out the cartridge dab a Q tip with alcohol and rub it on the cartridge nozzle identified by a copper square metal with black dots
Oct 15, 2009 | Office Equipment & Supplies
I am getting a quarter inch black streak that runs the entire length on the back of each printed page. Sometimes light and sometimes quite dark. I have tried changing ink cartridges but still get the...
You'll have to open up the printer and clean everything off. You probably have a feed roller with ink on it. If you refill, use ONLY inks made for your brand of printer.
Jul 21, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon printing in streaks
first check the nozzle (bottom of cartridge). if u dont see black spots around the nozzle line (many nozzle that form straight line, black long straight line, color, 3 short line), or a view of burnt, u can continue below.
blow the air hole till it drop the ink. then clean it with water. but note, dont wipe the nozzle, let them wet. u must wipe the contact with dry tissue before inserting it back.
otherwise, u must replace ur cartridge :D
Apr 11, 2009 | Canon Office Equipment & Supplies
Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Feb 26, 2009 | Canon PIXMA iP3500 Printer
What is causing black streak
You should try changing the toner cartridges first. There may be something stuck in it causing the noise and streaking
Apr 14, 2008 | Canon imageCLASS D661 Digital Printer
Canon PC-940 Black and White Copier Logo
97 people viewed this question
old marine
old marine
