Question about SanDisk Sansa c150 MP3 Player
Sansa e150 finish update browseDB
I turn on th mp3, and appears the next mesaje "finish Update BrowseDB", and i cant do nothing it still happennig when i connect my sansa to the computer, i tried to start my mp3 in recovery mode and conect to the pc to upgrade the firmeware but dont works and the installers said that it fails, could some body help me thanks.
  • 1 more comment
  • rajnish1 Nov 06, 2007
    i loaded mp3s on the c150. after i disconnected the cord from the pc, it said start update browseDB, then finish update browseDB and than hanged. it has not worked since. even if i take the battery out and replace, it does the same. my pc doesn't recognise it and it wont take a reset with vol+ +select button. help!!!!
  • vamshiskatin May 16, 2008
    i turn on th mp3, and appears the next mesaje "finish Update BrowseDB",
  • kumard2k Aug 15, 2008
    Hi i have the same problem...
    plz help me
    frwd any sugession to my mail kumard2k@gmail.com
    Thank you
    Dhanu
Dude, I realised it had 1 yr warranty, I returned it and they gave me a new one. The company support said there was NO solution!!
Posted on Nov 05, 2008
En español
Posted on Nov 04, 2008
I dont have sandisk driver for my sansa E260..i cant transfer songs..
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Dec 01, 2010 | SanDisk Sansa e260 MP3 Player
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa Deleted my music?
Your music is still there, check out my tip posted here...Solve your MP3 Player Connection Problem.
May 31, 2010 | SanDisk Sansa e250 MP3 Player
My sansa fuze wont play i know it has power in it because the blue light surrounding the center dial is lit yet i cant get a screen to come up nor can i shut it off
Sandisk gives next support link, how to recover the player:
http://kb.sandisk.com/app/answers/detail/a_id/4/kw/blue%20ring/r_id/101834
Solution 1: RESET THE DEVICE
Scroll to the Sansa Fuze on next site, how to perform a reset:
http://kb.sandisk.com/app/answers/detail/a_id/188/kw/blue%20ring/r_id/101834
When solution 1 did not help.
Solution 2: RELOAD AND UPDATE THE LATEST FIRMWARE
All data on the player will be erased when updating firmware !
Go to next sites, seeing how to do a firmware update:
1. To perform a firmware update the player has to be in MSC mode.
How to put the player in MSC mode, see the information about the
Fuze player:
http://kb.sandisk.com/app/answers/detail/a_id/61/kw/blue%20ring/r_id/101834
Putting Sansa Fuze in MSC mode:
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the left button ( |<< ) while connecting the device to the PC.
2. Continuing with the firmware reinstallation you can choose either automatic or manual update, see:
http://kb.sandisk.com/app/answers/detail/a_id/278/kw/blue%20ring/r_id/101834
Automatic update using the Sansa Updater.
or
Manual update going to Sansa Forums.
Need more help ? Just post a comment.
Dec 10, 2009 | SanDisk Sansa Fuze MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
Frozen screen
I was skeptical that this could work, but it has worked for me. Hopefully you will have success with it too. On the internet, I searched for this issue and one person said to put the battery in backwards, press the power button, put the battery in right, and then turn on the c140. I still had to format the unit in MSC mode, but it appears to be working correctly now.
Nov 04, 2008 | SanDisk Sansa c140 MP3 Player
Sansa c140
Download this file:
http://www.sendspace.com/file/0mc3km
This is the firmware update utility for Sanca c140 (c100 series) devices.
There is a howto.txt file included, follow the instructions.I am posting the instructions here for convenience.
1. Download the attached file and save it on the desktop.
(the player should not be attached to the computer at this point)
2. Double click the file to run it.
3. Accept the license agreement.
4. Remove the battery from the mp3 player.
5. Press and hold the center (select) button and connect it to the computer (keep holding the button, this is the firmware update mode).
6. If the New Hardware Wizard appears (now you can let go of the select button), do the following: (if asked, choose not to connect to the internet for updates), then choose to install the device automatically, then follow the prompts to finish the installation.
7. When the wizard comes up, or when the Update button becomes active (whichever happens first), you may release the select button.
8. Click the Update button, and then click OK to the message that comes up.
9. Wait until the upgrade finishes, then unplug the device.
10. Put the battery back in, and turn on the player.
11. Hopefully the update will be performed, then choose English for the language when prompted.
12. Check if the issue is resolved.
Jul 03, 2008 | SanDisk Sansa c140 MP3 Player
Sandisk sansa c140
Download this file:
Jul 02, 2008 | SanDisk Sansa c140 MP3 Player
Help with my 2 sansa c150 frozen!
all you have to do is let them run out of battery
May 16, 2008 | SanDisk Sansa c150 MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
259 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
