Question about HP Office Equipment & Supplies
Ive installed the software to run my printer and the computer's not detecting the printer. I bought a new usb cable today as i thought that may have been the problem but its still not recognising the printer, any suggestions?
  • 120 Answers
With the printer plugged in, press the windows key and pause. When system properties come up, click on 'device manager' and delete the printer from the list (just select and press delete). Close all windows.
Unplug the usb cable and plug it back in and windows should auto detect the printer again.
Posted on Dec 05, 2008
How do I plug in printer
first insert the driver cd and run the software and when the software tells to connect the usb cable at that time u power on the printer and connect the usb cable once the software detects the new printer it will complete the software installation
Feb 18, 2014 | Acer Computers & Internet
Have E Machine ET1161-05 trying to install Kodak ESP6150 computer does not find printer
While installing the printer just switch off the printer and try to install the printer driver completely, When the software will ask you to connect the printer then only switch on the printer. If this way still you are getting the same problem then connect the printer in other usb port or use different USB cable
Aug 14, 2012 | E-Machines eMachines Desktop PC
HI , i couldn't install my printer , after software installation the driver ask me to plug the usb cable but unfortunatelly , the device is uknown even if the usb port work properly and the usb...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . If not detected please contact service.
Thank you for using Fixya
Aug 09, 2011 | Office Equipment & Supplies
I bought the HP Deskjet 5650, but I'm not sure how to install it to my home computer.
First find the installation disk that came with your printer in the box. Install the software by placing the disk in your CDROM of your computer and then follow the instructions on the screen. when the software has finished installing, connect your printer to the computer with your USB cord and the computer will automatically do the rest.
Some operating systems already have the driver for your printer and the software is not necessary. To check and see if your computers operating system already has the necessary drivers, just connect your printer via your usb cord. Your computer will recognize the printer once the cord is connected and you will see a pop up message around the right hand corner of the monitor screen that says "new equipment detected" and the computer will do the rest.
Nov 11, 2010 | HP DeskJet 5650 InkJet Printer
My father bought me a new printer. The printer is a HP Deskjet D1460 and my laptop cannot recognize the printer. My OS is vizta
  1. Verify your USB ports are working properly by plugging any other devise. Eg. Pen Drive.
  2. You have to 1st install the software and then plug the printer, If you plug the printer before install software it wont detect sometime.
  3. Then If you are using a lengthy cable to connect printer, Try with a shorter cable. Some HP printers does not support long cables
Dec 17, 2009 | HP LaserJet 1300 Printer
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
How to connect my printer to computer
Connect the usb cable at the back of tower and turn on printer.. If printer software and driver is not installed than insert the disc and install it.
Oct 10, 2009 | Epson Printer
Hello I am unable to get my HP all in one printer working? it will copy a page for me, but I cannot print anything/
Did you plug in the printer before you installed the drivers from your installation CD? If not, you need to uninstall the hp printer drivers and unplug the usb cord from the computer.
Restart your computer, run the installation cd, and then after the HP installation says it's complete then plug the usb cable into your computer. NOTE: Some HP driver installations ask you during the install to plug in your printer so the software can find it. If thats what happens then only plug in your printers usb cable when the installation software tells you to. Once it detects your printer the installation will continue. Make sure you keep hitting next or continue until the software tells you everything is installed. Now your all in one printer should work.
Wilcocoop
Dec 09, 2008 | Office Equipment & Supplies
Have a Dell Inspiration 1501. Installed Lexmark 5200 printer software some time age. Did not try to print until today and cannot get it to print. It will copy. Help
Disconnect printer from computer
Cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
Reboot & reconnect printer (swap cables if not detected)
If still not working, Uninstall the printer and install the printer again but
doing this:
1) Uninstall the printer,
2) Delete all the printer folders created during the last installation. (Usually in folder "Program Files")
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
This will fix your problem.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 19, 2008 | Lexmark Office Equipment & Supplies
Software Installation Problem
I had this problem just a few minutes ago. The way to get through this is to plug in the USB cable *before* you begin the installation. When Windows detects a device and ask for drivers you need to click cancel for each device (printer, fax, scanner, etc) that it prompts for.
Run the installation disc or file as normal with the USB cable plugged in and it should work. It worked for me.
-info
Windows Vista SP1
Feb 19, 2008 | Canon PIXMA MX700 All-In-One InkJet...
19 people viewed this question
Ben Johnson
