Question about HP Pavilion dv6000z Notebook
Doesnt stay on
I never use the battery i am always connected to the power. when i turn on my laptop it lights up but then shuts down immediately
    Scholar:
  • 37 Answers
Sounds to me like power cord failure.  it is running off battery power and with no power cord it cant recharge and shuts down to save data
Posted on Dec 05, 2008
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Computer shut down and won't turn on. With power connected, battery light flashes orange 7 times then nothing. Comp won't turn on. Attempted holding power button down for 30 seconds as seen in a forum. ...
If your pc will not turn on immediately it is possible that your laptop is overheating. Try using compressed air and blow out dust and dirt. If it still does not work, you have a faulty cooling system.
Apr 23, 2011 | Toshiba Satellite L305-S5891 Notebook
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. ...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. It always does the same thing: comes on for 1 minute, then powers down - there is no wait time in between unplugging and powering on. All fans seem to work and I cleaned the dust out of it. Help.
Nov 04, 2010 | Samsung HLN507 50" Rear Projection...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Can not get the power button to shut down the computer no matter how long I hold it down and the computer appears to stay in hibernation. Will not reboot or do anything when power is applied and power...
Remove the battery and leave off for about 1 minute. Put the battery back in place and press the power button to turn the unit on. immediately after you see system light come on, press and hold the power button and see if it shuts off after a few seconds. If not, then its likely your motherboard is defective.
Sep 07, 2010 | Toshiba Satellite M100 Notebook
Laptop would start up but shut down immediately and the battery w
How long does it stay on for? I had a similar problem. Mine would stay on for 10min then shut down. It ended up being an excessive build-up of dust around the cooling fan. If your problem is similar its worth taking a look at. Good luck, Todd
Dec 22, 2009 | Toshiba Satellite A25-S207 Notebook
I have an extensa 5420-5687. 1 day my laptop just
the power cord has shorted out you will need to buy a new one
If I have helped you please click the yes this was helpful button
Dec 03, 2009 | Acer Extensa 5420-5687 Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Computer starts and stops within seconds but batt light is solid green and pluged in
Ensure That your Power button is clicking back and staying connected - this would cause the computer to shut down immediately.
Feb 04, 2008 | Sharp Actius AL27 Notebook
HP Pavilion dv6000z Notebook Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
