Need a starter clutch; can i have my starter clutch rebuilt on my 2006 yamaha 1100 v-star custom?
SOURCE: instaling a clutch for a 2001 yamah v star custom
go here for free pdf download service manual
http://www.carlsalter.com/download.asp?fileid=089097109097104097095086083084065082095054053048095077065073078095077065078046112100102
SOURCE: where is the oil filter on my yamaha V-star 1100
On the right side of the bike (right side when ou are sitting on it) just above the rear brake lever behind a small circular plate. remove the plate and the oil filter is inside (you will easily see it). Warning---on these bikes you have to drop the front exhaust header and right floor board in order to change the oil filter unless you install a after market oil filter relocation kit. If you plan on changing your own oil it is highly recommended to install this relocation kit.
SOURCE: how to remove the starter clutch on a 2003 yamaha
It is on the back side of the flywheel for the magneto/generator. You will need to remove the left engine side cover then pull the flywheel. It does take a special puller to get the fly wheel off. Once you get the flywheel off, there are 8 allen bolts that hold it to the back side of the flywheel.
http://216.37.204.203/Yamaha_OEM/YamahaMC.asp?Type=13&A=374&B=14
http://216.37.204.203/Yamaha_OEM/YamahaMC.asp?Type=13&A=374&B=37
SOURCE: Yamaha 1100 Drag Star 2001 Custom motor starter,
These parts are fairly reliable. Rather than buying new, you should be able to pick one up from a motorcycle breaker who will post it to you. I would expect to pay about £60-£100 tops in the UK (Depending on mileage). ANy Yamaha dealer will be happy to order you one new, but they are a hell of a price!
