Question about Whirlpool GU2400XTP Built-in Dishwasher
Loud Whining/Humming noise while washing
The dishwasher functions normally except for the following problem. When it is washing it makes a loud humming/whining noise. The washing cycle periodically pauses and the noise disappears but starts again when the dishwasher resumes washing. I checked the chopper assembly and removed any debris from this area and the sound remains. I also ran throught the diagnostic cycle and the noise is only evident when the wash motor is running. If the problem is in the pump motor or pump sump is there a good way to find out which it is? Any help is appreciated.
  • 6 more comments
  • Anonymous Dec 24, 2007
    ditto
  • momof2boys Dec 27, 2007
    I have the same problem, any advice is appreciated. I will probally get stuck calling a repair man.
    momof2boys. Arizona
  • Anonymous Dec 29, 2007
    Our Whirlpool Gold just started making this same annoying noise about a week ago.
  • Anonymous Jan 20, 2008
    Exact same problem and it drives me crazy to hear it keep humming and humming. Please find a solution to this noisy issue.
  • ppiiigg Mar 22, 2008
    Same problem, loud intermitent whining and humming just started after 12 months and sounds like the pump is going out... also had to replace tips on racks with plastic caps...
  • kathyaustin Apr 02, 2008
    we have the same problem, LOUD Noise during the washing cycle, quiet rest of the time.  My machine is only 2 yrs 3 months old.  Called Whirlpool repair and they said it is probably the pump which will need to be replaced.  I am not very happy as it isn't that old.  I let you know.   KathyinAustin
  • ironbutt Nov 22, 2008
    Same symptoms; I have to wonder how longer other's symptoms lasted before the motor was replaced or failed.
    Paul C
  • Anonymous Dec 04, 2008
    Exactly the same
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Posted on Mar 22, 2008
    Depending on how old your machine is, any of these problems may be the culprit...
When the dishwasher first comes on there is an intermittant rubbing sound. Any ideas?
Posted on Jan 15, 2009
I've got the same issue with my whirlpool dishwasher, model GU1200XTLS. If I find out anything, I'll let you know. Have you received any insight?
Posted on Feb 25, 2007
Why does it make a loud Humming noise?
Something is still in the main wash pump, you hear the motor trying to turn the impeller and it can not
Mar 27, 2016 | Dishwashers
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
What could be causing my car to be making a very loud humming/whining noise at idle
bad/loose belt, bad/going water pump. bad/going alternator.
Apr 09, 2015 | 2004 Mazda 6
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
Dishwasher was making a loud hum. I turned it off and started it this morning. Seemed to be working fine, but after about 5 minutes it started making the same loud hum. The first time it seemed to be...
The loud humming noise can be due to the pump sticking if a piece of debris gets trapped in it or an intermittent fault on the pump capacitor or starter relay.
Check out these links below to get tutorials and advice on how to clean the pump or change the capacitor or relay which is cheap and simple job. How to replace Dishwasher pump Bosch Siemens etc Dishwasher Repair Manual Table of Contents http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes.html?start=25
I hope this helps
Feb 05, 2018 | Jenn-Air 24 in. JDB1100AWS Built-in...
Vfr 400 nc24 whining noise when engine is reved
The loud whining noise is just normal for vfr 400 because it is gear driven cam.. As you reach 5000rpm up, the bike's electrics try to misfire the plugs so it would act as a speed limiter (180kph).. You have to bypass the sensor at the speedo..
Sep 28, 2009 | 1988 Honda VFR 400 R NC24
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
May 06, 2009 | Amana Washing Machines
Whirlpool Dishwasher Model: GU2500XTPQ3 making loud whining noise
It's most likely coming from the wash motor bearings. Based upon the age of the dishwasher it might be time for a new one. Although it can be fixed by replacing the motor. It's usually easiest to change the entire sump assembly with the motor. You will have a new wash system. Part number W10782773 Dishwasher Pump Motor Part Number 8535150 Sears PartsDirect
Feb 22, 2018 | Dishwashers
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
4,302 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
