Question about HP LaserJet 2605dn Printer
2605dn says "replace supplies" points to black
I replaced black as directed with new cartridge and still have problem. Manual says "replace supplies" only shows when either yellow or majenta are in the cyan slot. This not the case. All colors are correctly installed with new black and still will not print. (showing "replace supplies"
  • jwmbulte Jan 14, 2009
    same problem but i do not undersatnd the solution that was given previously, how do i "override"?
  • jenny_jane Jan 22, 2009
    I did the override in the control panel and it printed a test page that was fine, but now nothing happens when I send a file to print. Not sure how to clean the "cartridge contacts" and "HV pins."
  • 47 Answers
You might have an issue with the cartridge lockers. Be sure to clean cartridge contacts and HV pins in printer. Doesn't help? Do like this. In the printers menu, under system set up, then print quality, then replace supplies there you can choose override out. Print a status page and check status for the cartridges, if the printer don't prints in override mode you have a brooken cartidge locker. In that case, remove all toner cartridges and check the lockers by moving cartridgedoor in and out, do all works the same way or is any of them different?
Posted on Dec 08, 2008
How to solve the Replace Supplies in HP Colour LaserJet 2506
If cartridges are fine, you can Override the Replace Supplies Message. Follow the instructions given below from (Page 146) of HP 2605dn Manual
I have done it myself and it works fine. Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Mar 04, 2011 | HP Color LaserJet 2600n Printer
The screen reads "replace supplies" - it does not
Good Luck!
CreativeTECH
Dec 22, 2010 | HP LaserJet 2605dn Printer
Replaced cartridge but message still indicates "replace supplies".
Good Luck!
CreativeTECH
Dec 17, 2010 | HP LaserJet 2605dn Printer
I have an hp color laser jet 2605dn. I have lost my manual and it won't allow me to print. The screen on the printer says replace supplies. I have new cartridges in and it still is saying that. What...
Supposedly the operator panel should display a "supplies gauge" which should display the status of what needs replacing.
You are using HP cartridges?
Dec 05, 2010 | HP Office Equipment & Supplies
2600n all 4 cartridges are locked and the printer saying replace supply error
Good Luck!
CreativeTECH
Nov 11, 2010 | HP Color LaserJet 2600n Printer
Even though I have the settings on B&W print only, my color ink cartridges run out the same time as my black ink - or so says the printer. Any way around that?
Good Luck!
CreativeTECH
Oct 10, 2010 | HP LaserJet 2605dn Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
HP 2605dn Black prints 1/8" offset to left. Colors do register
Missalignment problems ae not uncommon with this series of printer.
The cause is one of the sensors (which are used for calibration and alignment) on the transfer belt, is faulty.
These sensors are NOT availale, and replacement of the transfer belt is the solution.
Transfer belt replacement on these printers requires quite a bit of dismantling, its not considered to be a user replacable consumable.
832 people viewed this question
Seeker5211
Seeker5211
