Question about HP Office Equipment & Supplies
I opened the printer box for the first time and the USB connection core is missing. Without it I cannot get to step 11. Will you send me one? I checked box and wrapping very carefully.
  • 120 Answers
Some printers do not come with usb cables (so they can make more money off of us), but they can be purchased very cheaply from WalMart.
Posted on Dec 05, 2008
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
Hp pavilion a1710n doesn't send to printer. Goes through every step,doesnt send. My laptop workds with the printer.
A few things come to mind. Are you sure the printer isn't a D4160??? The C4160 was sold in England. Anyways...
First, when you hit print a box opens up. On the top of that box make sure your printer is the one selected. It will have a green checkmark by it.
Second. Make sure the USB cable is connected between computer and printer. The Hp pavilion a1710n doesn't have a wireless network chip so it will need the USB cable connected for it to print.
I assume your laptop prints wirelessly and that is why it works and the HP does not.
Good Luck
Dec 07, 2013 | HP Pavilion Computers & Internet
Got "Ink System Failure" message. Followed step by
Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 06, 2011 | HP Officejet 6500 Wireless All-in-One...
Hi, all i want to do is install a printer without the software thank you Jay.
You can add a printer though the print wizard built into Windows XP.
1. Open the add printer wizard.
2. Then select local printer... even if it is a network printer
3. If you are not using a USB cable to connect you printer, uncheck the box next to "automatically detect plug and play printer". --->click next. If you are using a USB cable Skip step 4.
4. Your selection on the screen depends on how the printer is connected. In you are using a parallel cable, you will selct the radio button next to "Use the following port" and select LPT1 from the dropdown box. If your printer is a network printer, you select "create a new port" and Standard TCP/IP port from the dropdown box. Then, enter the printers IP Address in the next dialogue box
5. When you come to the install printer software screen click "have disk" and navigate to your machine specific .inf file
6. Enjoy your printer without the annoying bells and whistles
Oct 29, 2010 | Epson Stylus CX5400
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
Can oper Kodak home center but cant scan or print from it
No you can't print. You need printer icon to operate.
You can try follow steps.
go to device manager ,   expand Universal Serial Bus (USB),  right click on USB Composite Device, Uninstall it. Reboot your computer. You will get a printer icon,
and you can start printing without AIO Home center.
MS
Jun 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How Send EPL2 commands to USB
Use the Zebra ZUD driver. Latest version V5.5.7.25 (Download from Zebra website). When driver is installed, go to printer & Faxes folder and double-click on the installed printer icon.
Click Printer/properties/printer/advanced (+)/tools (Click on tools) This opens a text box. Type commands in here and send directly to printer. E.G type U click send and it will print a config sheet.
This definately works.
May 14, 2009 | Zebra TLP 2844-Z Thermal Label Printer
24 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
