Question about Kyocera Mita Office Equipment & Supplies
Flashing "replace unit" light
I want to reset the copier so the "replace Unit" light doesn't flash.It still makes good copies, and I don't want to replace both the drum and developer to get the light to go off.
  • 2 more comments
  • upub5 Dec 06, 2008
    The first advice did not work. I removed the units, disconnected from power for 2+ minutes, then reinstalled and still flashing red light. There must be something with a new drum/developer that triggers the "replace unit" light to go off. My drum and developer are still making great copies!
    Hello
    I pressed the buttons as directed. I pressed stop/clear a 2nd time; copier reverted to normal mode and not I am not sure how to "enter 73 print menu".. I entered "73" in page count, but no menu appears, etc. Meanwhile, copier thinks I want to make 73 copies and just starts to copy.
  • upub5 Dec 08, 2008
    Hello
    I have a Kyocera Mita Copystar CS-2114 copy machine. I need to get the flashing "replace unit" light to go off so I can resume normal copying with the perfectly good drum and developer unit that is currently in it.
  • upub5 Dec 09, 2008
    I don't know how to reach the manufacturer tech support line and doubt one exists. There is a way to reset so that the drum count goes back to one. I have done it with my Xerox copiers.
    Genius:
  • 1,239 Answers
HI
here is the fix: Press "C", press the exposure button (below the picture of the little man), press "C", press the exposure button. When you do this all the indicator lights will turn off. Now input "24", press the green start button, input 07, and press the start button again. Now turn the copier off and back on with the power switch on the side.
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "24", "Start Key", "7", "Start Key"
Posted on Dec 09, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 09, 2008
    go to the menuel button and scrool down until you see reset count.do not silect toner reset.choose drum reset and enter and it will (0) out.
    Read this thread...You might need some help from a technician..
    http://www.digitalissues.co.uk/html/hard...
  • ABHISHEK.C
    #, *, c, * very quick then 14 print is reset, if it comes back after reset then it needs fuser/fuser lamp.
    P, *,C, * 14 very quick then 14 print is reset, if it comes back after reset then it needs fuser/fuser lamp.
    if you want to reset the entire machine though here is the procedure.
    1. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
      The CE Mode - Password Entry screen will appear.
    2. Enter the Access Number 6789 and press Confirm.
      The colors on the display are reversed to indicate that UI Diagnostics mode is active.
    Sergeant:
  • 399 Answers
Key the front door. To enter service mode hold clear/stop and print while powering ON. Using the + keys increment up to simulation 60, press print to start. Adjust the toner control VR on the front of the developing unit to center the LEDs on the exposure indicator. Press clear/stop to stop. Power Off/On to exit simulation mode.
If you cannot center the LEDs. Developer must be new. Clean the toner sensor surface. Check the doctor blade is set to 1.05mm, and mag brush to 18mm. Leave the toner hopper and front cover off of the developing unit. Remove the back cover. Run simulation 60 for several minutes to completely stir the developer.
If LED's show 1) Always Light, 2) Always Dark, 3) Irratic
While running simulation 60, meter pin 3 of the developing unit plug to ground from the back of the copier (center pin, top row). This is the toner sensor output. Ideal value is 2.7VDC. Acceptable range is 2.5 to 2.9VDC. If it is not, adjust the VR within the toner sensor accordingly, or replace the toner sensor. A problem with the toner sensor is usually seen as 1) Always Light condition and readings from 3.0 to 4.5VDC.
With 2) Always Dark or 3) Irratic, stop simulation 60. Remove the developing unit from the copier. Meter pins 5 to 10 on the 20Kohm range (the two pins to the far right as viewed from the back), while turning the developer setting VR. Readings should range from 0 to 4500 ohms. Readings of 4500 unchanging, or irratic indicate a faulty developer setting VR. Replace the VR with Mita part # 73928070 Toner Density VR PCB (or Radio Shack part # 271-280, PCB Mount 1Kohm Potentiometer). New developer sets correctly around 700 ohms on the VR.
This procedure works on the Mita DC2114/2113. The only difference between that and the Mita DC1415/1435 is that the mag brush setting is 20mm, and the developing unit plug is rotated 180 degrees.
Posted on Dec 08, 2008
  • 4,472 Answers
First off can i have the specific model printer you are referring to not just the make. After I have that information I can assist you properly. Please don't request more help until I have finished assisting you.
Thank you,
lee
Posted on Dec 06, 2008
    Genius:
  • 1,061 Answers
NEED MAKE AND MODEL.RICHARDM69..BELIEVE I CAN SOLVE YOUR PROBLEM IF GIVEN THE INFO RICHARDM69
  • Desktopsbyduck-Computers
  • Kyocera Mita Master
  • 19,396 Answers
This should be the reset procedure for Kyocera Mita, if I remember well:
enter the service mode holding down the buttons print and stop/clear, and starting the unit at the same time, then leave the buttons and press again stop/clear
Enter 73 print menu, there you can reset lamp counter. Restart the unit to complete the procedure.
I will also be grateful if you can rate the solution after this work.
Posted on Dec 05, 2008
  • 2 more comments
  • Ginko
    Ginko Dec 06, 2008
    You need to reset the counter from service mode. The point is how to enter in service mode.
    There are different procedure , depending on the model.
    I remember you start service mode holding down the buttons print and stop/clear, and starting the unit at
    Enter 73 print menu, there you can reset the counter to 00.
    Here is a different reset for KM 1505.
    I must have also service manuals for a couple of models.
    Post the model.
  • Ginko
    Ginko Dec 06, 2008
    You enter the nr 73 to chose the menu when you get 00 that means service menu.
    that depends on the model ,
    give me the model before entering in service mode..
  • Ginko
    Ginko Dec 06, 2008
    Give me the machine model, if you use the wrong service menu you mess up the machine settings.
    Tell me the exact model.
  • Ginko
    Ginko Dec 06, 2008
    Thanks guys I was desperate,
    We need the exact model sir.
    Sergeant:
  • 217 Answers
Remove the unit and the toner.and shut off the printer,also remove it from the power outlet for 2 minutes.then agasin connect it should get resetted but if not then will have to replace.
    Top Expert:
  • 77,169 Answers
You may indeed have to replace the unit, have you called the manufacturer tech support line?
Will print but not copy - power light is flashing
check settings power down and back on to see if it will reset .
Mar 15, 2015 | Office Equipment & Supplies
Tip
Sharp AL2020 AL2040 AL2060 Copier Drum Light Reset
So maybe you have replaced your drum but the light did not reset. Or your copies are fine and you would like to get more copies out of the drum unit rather than just replace it. Here is the procedure.
Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" key then the "Auto" key, then the "C" key then the "Auto" key again.
So in other words C, Auto, C, Auto
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's or "Drum Reset" on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Works on the Sharp 2020 2040 2060 as well as others.
Good Luck and Thank You for using Fixya.
WheatlandServices
on Dec 20, 2010 | Office Equipment & Supplies
Tip
Xerox XD or XC Series Copier Drum Light Drum Unit Reset Procedure
To reset the drum light on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
You should now be getting flashing zero's on the display.
This works on nearly all Xerox XD and XC Series copiers.
on Mar 20, 2010 | Office Equipment & Supplies
Constant flashing lights
These lights flashing are an indicator that something is wrong with the unit. Once the problem is solved the following steps will reset the lights so that they stop flashing. If you don't believe there is an issue you can try these steps and it will reset if nothing is wrong.
1.) Turn the refrigerator and freezer to 0 this will cause them to turn off.
2.) Hold Super Freeze and Super Cool buttons down for 15 seconds.
3.) Return your freezer and refrigerator temperature settings back to what they were before you turned them all the way down.
If this doesn't stop the lights something is still wrong with your unit and it is informing you of this.
I hope this helps!
Oct 20, 2012 | Refrigerators
The fuser error light is on and my Xerox XC 1040 copier will not work. There is no error codes displayed
The drum light can be reset via the control panel. Especially if your copies were good before the light came on. The drum unit is the cartridge that is located right next to the toner cartridge. Reset the light using the following reset procedure:
WheatlandServices
Nov 12, 2010 | Xerox Office Equipment & Supplies
How do I remove and install the "drum" on my copier? Drum light is on and I replace my cartridge toner. Drum light is still on.
If your copies are fine just reset the drum unit counter. To reset the drum light, press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
You can reset this counter at least once to get twice the life out of your drum unit.
Sep 13, 2010 | Sharp AL 1631 Copier
Receiving error code 6A00, and alarm light is
That error says the purge unit is broken. You will need to have the purge assembly replaced.
It's # QM2-3032-000 but a shop should replace it for you.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Oct 21, 2009 | Sharp AL 1631 Copier
3 flashing lights + "call for service" displayed and won't copy
This model was notorious for that code.
It is a Laser Unit failure. Some tech bulletins were issued reguarding installation of grounding straps or replacement of entire Laser Unit.
May 05, 2009 | Toshiba e-Studio16S Copier
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
