Question about Refrigerators
ELECTRONIC TEMPERATURE GADGE FLASHING AND BEEPING FRIDGE NOT COOLING
  • stacy07114 Jan 02, 2009
    My Master-Bilt Cooler is freezing everything.  The temperature gauge is always flashing and beeping but there are no instructions on how to reset the temperature.  It appears to be set at 27.
  • mylittlehumb Apr 13, 2009
    Thanks so much, thats a lot of info.....as it happens, there was a lot of build up of frost. I cleaned all that out.....took the excess water out of the bottoma dn its still not cooling the fridge and still flashing. It sounds like the fan is going but im not sure where it is to check properly.....anything else? I gues ill just have to have someone come out and fix it.
    Scholar:
  • 82 Answers
Hello.
The first thing you need to do is take out the bottom drawer in the freezer and look into the slots in the back panel. Make sure that you can see silver coils, and not a bunch of frost.
If this checks out ok, make sure that the coils underneath are clean and the fan is also turning (underneath the unit).
If all looks ok then make sure the fan in the freezer is running. (You may have to push the door switch if yours has one.) If the freezer fan isn’t blowing however, the freezer will be warm at the top and cool at the bottom, and you fresh food compartment will be warm.
Another thing to make sure is that the light it turning off when the door is closed. Again you would have to push on the door switch. I was amazed to learn when I first started this line of work, that even a little light bulb can make enough heat to cause a problem.
Let me know if everything looks ok and I will go over some other things.
Posted on Dec 05, 2008
Viking fridge top and bottom model#vcbb536rss is beeping sporadically, the display screen is flashing, what is wrong with that? what part we need to check?
high low voltage board were likely not needed
board registers high temp and after a few days of constant high temp alarm will restart
by replacing low volt board all you did is start with empty register also when replacing low volt board they have to be programed for your model
sounds like you need service for your cooling issue
May 31, 2017 | Viking Refrigerators
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
Jan 01, 2015 | Refrigerators
Frigidaire fgf379wjca wont stop beeping and diaplays door on control panel
When a cooling device starts beeping, see it as a warning it can't hold the temperature you selected. Could be the compressor does not work correct, could be it lost cooling fluid. If it keeps beeping, save the food by putting it in another fridge and start (or let someone start) finding out what is wrong. The door symbol is indicating the fridge thinks the temp rise is caused by an open door.
Jul 13, 2014 | Electrolux Dishwashers
Temperature controls seem to be playing up and then stopped completely
Try resetting system. Unplug for 10 min. Then plug back in. Set all temps. 36 ref. 0 fre.
Jun 18, 2017 | Refrigerators
RS2545SH. Fridge side is not cooling. Thanks
I have the same problem....anyone have a fix
Oct 18, 2009 | Samsung Refrigerators
Refrigerators Logo
589 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
