I want to install two beer tap faucets in the side of my fridge
I have a Kenmore 18cuft freezer-over refrigerator and want to drill two 1" holes in the side to install beer faucets. I'm trying to confirm that there are no wires or cooling lines in the side of the fridge compartment. It's a model R134a- P/N 240379010
Fast answer, great advice, just what I was hoping to hear! My homebrewed English style ESB thanks you.Fast answer, great advice, just what I was hoping to hear! My homebrewed English style ESB thanks you.
You can't post conmments that contain an email address.
Is this also true for a Kenmore Coldspot side-by-side Model 57572791? I'm actually trying to do the same thing as chuck_noll. Thanks!Is this also true for a Kenmore Coldspot side-by-side Model 57572791? I'm actually trying to do the same thing as chuck_noll. Thanks!
Good day, If it has the condensor coil mounted on the back of the machine. (black coil) then yes, VERY DANGEROUS. Refrigeration lines run at an angle from the bottom back of the machine at an angle and terminate at the bottom of the freezer door. This applies to both sides. Hit one of those and your finished.
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp. The problem could be the electronic control if
you have one or the mechanical linkages.
the most fridges i have stripped the pipes are on the left hand side and the power wires on the right hand side but if the pipe is drilled thru it is only the oil cooled pipes it can be disconnected the important piper are at the back of the frige i hope this will help you
Apparently there is no solution, I have been told that it is not possible to drill through the side or the top of this model with out ruining it so I give up
Any lines that run through the cabinet should go up the back or and/or around the door. I would carefully cut a hole in the liner and pull the insulation out in small peices just to make sure.
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator: Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI 1. Remove Worktop: Using a Phillips Screwdriver, remove the three screws located on the front underside edge of the worktop and the three screws located at the rear (back) side of the worktop. See Fig's. 1 & 2 Remove the worktop from the cabinet and position the worktop on top of the cabinet so that the front corners are staggered across the front corners of the cabinet. 2. Installation of Top Rail: Attach the chrome rail to the work top using four self-tapping screws from the underside of the worktop through the pre-drilled holes. (attach the front ends of the rail first) 3. Re-Install Wo r k t o p : Install the front of the worktop onto the cabinet, then lower the rear side of the worktop over the backside of the cabinet. Secure using the same screws removed earlier. (the smaller screws at the front the larger screws at the rear) 4. Installation of CO2 Cylinder Support: Install the cylinder support onto the four studs located on the exterior back wall of the cabinet. (no tools required) Align the holes in the cylinder support with the studs and push down firmly. See Fig. 3 5. Installation of CO2 Cylinder: Install your " fully charged" CO2 cylinder into the support stand. IMPORTANT NOTICE: ALWAYS EXERCISE EXTREME CAUTION WHEN HANDLING PRESSURIZED C02 CYLINDERS: 6. Installation of C02 Regulator: Attach the CO2 Regulator to the C02 cylinder by screwing the regulator nut onto cylinder valve and tighten (snug) using an adjustable wrench. 7. Installation of C02 Air Line Hose to Regulator: Attach one end of the (red) air line hose to the hose barb connection on the CO2 regulator. Secure hose by using one of the two (self locking) black plastic snap on clamps provided. (use pliers to snap the clamp tight to assure that there are no leaks) See Fig. 5 Fig. 1 Fig. 2 Fig. 3 Fig. 4 Fig. 5 LL'N TAP ACCESSORIES (included with this unit)
