The silver part which you insert into the computer came off my flash drive is their a way to get it back attached to the green card inside of the flash drive?
    Scholar:
  • 37 Answers
Yes you can solder it... if you are not confortable soldering take it to someone who is.  Im assuming by littlesilver thing you are talking about the male part and not just the outer casing of the male part.
Soldering is relatively easy and straight forward.  just make sure you put it bac on the way it was suopposed to be to begin with.
If it is just the outer shroud of the male part , you dont actually need it but you have to make sure you put it in correctly every time.  the shroud is just really a guide to help you not insert it incorrectly and they ground it so you have a secondary ground for added prtection but its not really needed.
Posted on Dec 05, 2008
    Master:
  • 409 Answers
You will need to find someone with some experience in soldering. I suggest taking it to a repair centre. But, unless there is data on it that you require, it may be cheaper to buy a new one.
Why when I go to review my pictures I get a black screen with a white box made of hyphenated lines no pictures
take out your memory card an insert it in a computer .
go to my computer
right clik on the drive letter for it . (be careful its correct drive )
an format it fully , not a quick format
then try it again.
try running the camera w/o memory card in it or put in another if not solved.
lots of fake memory cards being sold right now too.
Jun 17, 2014 | Olympus VG-150 12.0 MP Digital Camera -...
My memory card is not detected by my computer it says please insert disk
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
Aug 12, 2012 | Electronics - Others
Flash Drive (Kingmax) cannot be read by the computer
if you need more help with post a reply
hope it helps
Jul 06, 2012 | Electronics - Others
Usb port not detected
if you need more help with this or if i have missed the problem post a reply
hope it helps
Jun 09, 2012 | Electronics - Others
Can't open my flash drive
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Mar 27, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My flash is unreachable and unformatable
hope this helps you
Dec 30, 2011 | PDP Systems Patriot Pef16grusb Xporter Xt...
How do I reuse a cd-rw disc over and over again.
Insert your cd-rw into your computer and then:
- Go to My Computer
- Right Click on the drive (in which you have just inserted the cd)
- Click Format
Wait for it to format. Then you can reuse it again.
Dec 29, 2010 | Verbatim CD-RW Rewritable Discs, Branded...
Computer shows the pen drive without its name. But when I try to open it gives message 'insert disk in drive F'. I started my computer keeping pen drive attached to it, in tis case, the message is ' format...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Sep 01, 2010 | Kingston 4GB Secure Digital High Capacity...
Can not find it
clean dust inside pin and insert ,refresh sys twice ,go to control panel check for external devices and get it
Sep 06, 2009 | PNY Attach? 1GB USB 2.0 Flash Drives...
Pny 16gb attachi flash drive reccognized by my computer but says insert disk into drive when I left click it
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 14, 2009 | PNY Attach? 16GB USB 2.0 Flash Drive
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
