Need help installing pc game
The game finishes installation, but goes back to main menu.wont let me play and the task bar says "gsc engine".
    Scholar:
  • 37 Answers
What game for one.  if it is an intense game with lots of graphics that makes your computer cry when trying to load then that could be your problem, it could be you have one or more pieces of hardware or software installed that conflict, it could be anything.  try installing it to a different computer and see f you get the same result.  if you do then your install files are corrupt, but if not then it is probly either a setting in the computer or a conflict.
Posted on Dec 05, 2008
Installing a computer game
you have to put the cd in the cd drive. then, in your task bar (which should be in your bottom right hand corner), you need to either click the expand button to see the icons in your task bar. you should see a loading cd icon; click it. that should then bring up a prompting screen where you should agree to install the game..... IF that doesnt work, you can just go to the start menu, then click on the "my computer" tab. this will bring you to a screen with the different devices hooked to your computer. left click the cd, then click install. Hope this helped you out!
Dec 29, 2012 | Computers & Internet
How can I play games?
Try going to your favorite search engine and looking up "free online games" without the quotes. Or go to the start menu and navigating to "Games" where you can choose a variety of pre-installed games. Alternatively, you can buy a PC game and install it to run on your computer. (just make sure your laptop has the correct minimum requirements or else the games wont load up and run properly)
Jan 15, 2011 | Computers & Internet
I installed a pc dvd game in my computer...the problem is, it hangs during the game. is there a step that i missed or have i installed it in a wrong procedure? can you show me the correct steps installing...
There is problem with the installation as there the installation procedure for games or any other software are very simple and straight forward so do not blame your installation.
There can be two reasons why the game becomes stuck
(1)You do not have enough RAM (For instance the game requires 800 MB and your PC has 512MB of RAM)
(2) Your CPU might be slow (like its 800 MHz while the game requirement is 1GHz)
To check this
(1)On the bottom of your Windows there is a task bar.
(2)Right click on it
(3) On the opening pop up menu select "Task Manager"
(4)On the opening window at the top tabs select "Performance" tab
(5)Turn on the game and observe the bar graph behavior of your CPU and RAM and you will easily find out which components of these two are being over used.
If there is lack of RAM or/and CPU you have to upgrade your computer or may be get a newer faster PC.
If you believe that there is nothing wrong with your hardware then check the media of your game. The game software might have corruptions. The DVD might be damaged you might find scratches on the DVD disc when you hold it at a particular angle on the disk.Try another DVD of the same game to arrive up with a solution.
GOOD LUCK !
Oct 11, 2010 | Computers & Internet
I just bought CoD Mw2, the installation went without any problems, but whenever I try to start the game; I get to the start menu and then the screen freezes, this happens to both single- and multiplayer....
Yes. This happens everytime. Here's a secret/glitch/whatever: when it starts, dont click anything. wait for the game to load up to the main menu. For example in Single player: just leave the keyboard/mouse. wait for all the short clips to play. after you get to the main menu (Spec Ops; Campaign; Multiplayer)Use your arrow keys to choose which. For example: I want spec ops. I just hit the left arrow key once. It might still freeze, but after awhile, it will be highlighted/selected/whatever. hit enter. then wait for it to load. then keep repeating these steps on what level/difficulty. then after you play a game, everything will go back to normal unless you quit again. That's all. Plz rate me.
Jan 06, 2010 | Activision Call of Duty 4 Modern Warfare...
Pc Game Error
Hi! I'm trying to install My Horse and Me the PC game, the installation goes through everything normal and but when I press Finish it gives me this error message
Unhandled Exception
Error Number:0x80040702
Description:Failed to load DLL:GameuxInstallHelper
When I press OK the installation window where you press Finish pops back up and it says
InstallShield Wizard Complete
The wizard was interrupted before MyHorseAndMe could be completely installed.
The system has not been modified.To install this program at a later time,run the installation again.
Click Finish to exit the wizard.
So I press Finish and then if I try to go and find it its not there its been uninstalled. And I have tried installing it several times with no luck .
So if you could please help me that would be wonderful because I really want to play my game.
Thank You!
Nov 14, 2009 | Atari Video Game Consoles & Games
Game installs 100% ,starts updating system files, wont finish.
You need to keep the Age of Empires install disk (usually labeled "Play Disk" or is just Disk 1 in older games) in your disk drive while you play the game.
Jun 01, 2009 | Microsoft Age of Empires: Gold Edition for...
Game installed but won't load to play
I have two computer games which are installed into my PC. When I click on the icon(s) nothing happens - in fact, for one of them I get a black,blanck screen which immediately reverts back to the desktop - WHY?
Mar 13, 2009 | M2K Garfield: It's All About Math Math...
My pioneer cd rw/dvd rw drive stoped working
what u might have to do is a system restore, which will restore the system to the date that u installed mortal kombat 4.
if u are using vista, just type system restore in the search bar, then back date the system to the date to the date u installed mortal kombat
if u are using XP, open "Run" on the start menu, type "msconfig" then click " launch system restore" on the general tab, than back date the system to the date u installed mortal kombat.
well.........i hope this works for you.
Mar 08, 2009 | Acer Aspire 5520-5908 Notebook
When i start diablo 2 and click play it goes black
Try a fresh install of the game.
Completely un-install the old one first and then reinstall.
Should remedy your problem.
Feb 04, 2009 | Diablo 2 Collector's Edition
I just purchased the cd-rom 'the worlds best Mahjong games and I'm trying to install it but I dont get an icon to click on or the word play so I dnt know how to get into the game Please help me my email...
hi,
if you successfully install Mahjong games in default it automatically install in your desktop the game icons. But now a days, program/game makers asking your permission to install the icons in the desktop and shortcut icons in the task bar and if you un check those permission you cannot see a shortcut icons in your desktop.
try to see it in the START Menu Programs. look for the game if there's a drop down menu look for the game icon and right click it. if no drop down menu just right click it. and go to send to and click desktop and now the game icon is already displayed in your desktop.
if you can't see it in START Menu Programs. Please re install it.
Nov 26, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
