Hi,my juno 60 has been working fine until recently, the problem is this whatever patch i'm on it resets itself back to manual i.e (- -)this shows up. any suggestions as to the cause?..cheers in advance!
4 Suggested Answers
SOURCE: Kenwood DVR - 7000
Hi, same thing happened to my one of the above. I bought a cheap dvd player to view movies and run the audio through the kenwood to use the surround speakers.
Posted on Oct 05, 2007
SOURCE: World of Warcraft latest patch-Cannot Validate Game Version
there are a couple things u can do. U can delete the path and redownload it, u may have gotten a bad copy of the patch. Second thing u can do is to completely uninstall wow and reinstall it, this may take a while so do it on a day that u have time.
Posted on Oct 20, 2008
bugoy31
  • 1238 Answers
SOURCE: Hyundai 32
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 08, 2012
My GEM WS1 workstation keyboard won't turn on , yesterday it was freezing while I was playing so I had to restart it a couple of times and it worked fine until today I played it and after a while I left it...
Hi Salma I don't knwon if it will help but with in order to reset the WS2 (wich is likely the WS1) you should press simultaneously the 4 first patch buttons and the 4 last patch bouttons
Dec 23, 2014 | Video Game Consoles & Games
1998 dodge 2500 4x4 pickup speedo and tach problems
You just go to the link I attached I'm sure you will get the solution of your problem
1998 Dodge Caravan Service Repair Factory Manual INSTANT DOWNLOAD
Dec 08, 2017 | 1999 Dodge Ram 2500 4WD
I can't find the codes for bluetooth pairing.
Normally, the 'factory default' paring code for a new bluetooth device is - 0000. Try this first.
If 0000 doesn't work, then try resetting the cd player back to factory settings (contact the manufacturer for further assistance).
Nov 28, 2011 | Car Audio & Video
Turns off and on its own every minute or so.
hi..
This problem will be there in ur tv until you put in a new Lamp. Working fine since then.I Got it through Amazon from www.vanns.com..
thank u
rate me
Aug 23, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
2 navlinks with the same problem
Hey Guys
Found a patch that fixes this issue
Applied it to both my Navlinks and both are working fine now
Attached is the link
http://www.navsupport.net/gps/quickfix/index.html
hope this helps anyone else
Jun 20, 2009 | GPS
Canon sd400 won't zoom out
Tr to reset your camera.Look in your manual that came with your camera to find the reset button.If resetting does not work then it is a mechanical failure in the camera.Contact the manufactor.
Jan 01, 2009 | Canon PowerShot SX100 IS Digital Camera
No Connection...
Have you tried doing the resetting in the following strict order?
1. Turn Everything off.
2. Turn on all satellite related components, wait a little then also turn on modem. wait 60 seconds until machine is up and IP is ready.
3. Turn on router, wait 60 seconds, allow IT to get its IP and setup itself.
4. Turn on computer.
Sometimes doing it in order is all it takes to make the machines act correctly.
May 15, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
114 people viewed this question
 Grubhead
Grubhead
