Question about Teac Audio Players & Recorders
PC-D320 Am/FM/Radio Cassette/CD player - CD won't read. The CD did read/play music, but would sometimes play in mono, moving CD selection switch would provide stereo sound. No CD cycles to last track and stops.
SOURCE: Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Posted on Feb 02, 2007
SOURCE: seems to only play in Mono
Karen - Is it only the FM section that is giging you trouble? Does Stereo work for the other inputs - VCR/DVD/Turntable?
Is that stereo button ONLY for the FM section?
Posted on Jun 17, 2008
  • 4234 Answers
SOURCE: Dialog track not playing for a 5.1 DVD
Unfortunately without "surround" processing, the center speaker will not work at all. It sounds like there is a problem with the center channel amp which is part of the receiver. This should be a single amp IC attached to the heatsink. There should be a "test" moe that will send white noise to each speaker in sequence. Try that. If that results in no sound to the center, it pretty much concludes that the center amp needs to be repaired. The part cost for this should be around $25.
Dan
Posted on Dec 04, 2008
bernardlunda
  • 318 Answers
SOURCE: Manual required. FM reception is not sounding like stereo.
get connected to
www.audiokarma.org/forums/archive/index.php/t-83626.html-20k for your manual
Posted on Apr 27, 2009
SOURCE: Hi, Experts, Vintage Sansui 5050 receiver.
Check for 19 Kz on stero decoder that requires calibration adjustment.
Instrument you need:
Occiloscope or frequezy counter and adj driver .
Good lock.
Posted on Jul 28, 2009
Tip
How can I connect an iPod to work through a car stereo?
<p>An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities. <br /> <p><br /> <p>Tape deck <br /> <p>1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end. <br /> <p><br /> <p>2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20. <br /> <p><br /> <p>3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player. <br /> <p><br /> <p>FM Transmitter <br /> <p>1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal. <br /> <p><br /> <p>2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent. <br /> <p><br /> <p>3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play." <br /> <p><br /> <p>Extra- <br /> <p>1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car. <br /> <p><br /> <p>2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10. <br /> <p><br /> <p>3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start. <br />
on Aug 09, 2011 | Apple iPod touch
Indash am/fm cd cassette player keeps spitting out cd's
Your CD may not be music CD. Some car radio doesn't accept MP3 or WMV files. Change it to a good radio such as JVC car radio.
Aug 22, 2014 | JVC AM FM CD DET FACE CAR STEREO
Radio trouble shooting
It seem like the stereo for the radio is failing, either because of a weak radio signal or defective aerial
Jul 30, 2014 | Mercedes-Benz 1992 Mercedes 500SL Radio /...
Cassette player doesn't work
tape is in wrong or heder needs to be cleand.
Nov 22, 2011 | Audio Players & Recorders
Cassette drive turns, speakers hiss but no music
Mode switch trouble! no audio from cassette function?
Nov 11, 2008 | Sony Walkman WM-D6C Personal Cassette...
Denon UDM3 SHELF SYSTEM
Hi MadLad,
There are several things to consider re this fault.....
Normally on small systems there is a selector switch to allow you to select what you need to listen to...for example if you want to play a CD then you select the CD mode, insert the CD push play and away it goes....
In your case you need to select Radio, or maybe select AM or maybe select FM, one of these should be accessed from a digital read out menu where you select your requirements.
Please have a good look at the operating manual to see if you can work out how to select the required listening mode, and you will be sweet...
Cheers From YUBEUT
Dec 14, 2007 | Denon DM-33 Shelf System
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
