Question about Gateway MX8711 Notebook
CD/DVD drive is not working
After putting in a CD and/or a DVD, my computer is not reading. It runs like it wants to read, however, it will not recognize the drive at all, nothing happens. I am working on a MX8711 Gateway Notebook, Microsoft Vista.
  • Dreea1 Dec 17, 2008
    I have the exact same problem as kellyadolph. I looked in the boot area and it says "none". It did work at one time, but now it just isn't there. I looked in the device manager, I'm not sure if I'm in the correct spot, but I don't see anything about a CD/DVD. What do I do to make this work????
  • Joe May 11, 2010
    Is the CD/DVD listed in the device manager? If so does it have a yellow ? on it?
My daughter has a C551 NR running vista. The CD\DVD Rom stop working in Vista so I used an external CD drive to install Windows 7, works great. . I ordered a new drive upon HP recommendation 435778-001....
should recognize the cd rom /dvd unit automatically
lower picture is of the c300 cd unit
anything look different from the original ............lowest picture
CRX880A Compaq Presario C305LA C508US C551NR Optical Combo Drive CD-RW DVD- ROM
Apr 17, 2017 | Compaq Creative Sound Blaster PCI 128...
Hello felows ,, i have a XP lap top ,, my problem is that the cd drive reads dvd , cd -rom , audio cd ,, but when i put a dvd - raw , it wont read it ,, the cd is a hp deskjet 2050 j510 series to...
No all cds/dvd work in all cd/dvd drives. I suspect your drive cannot read that make of cd although anothers cd rom can. Try making a copy of the disk on someone elses pc and try that in yours and you will probably find it works. You could always copy the cd to a pen drive and install it on yours from that.
Jun 03, 2011 | Computers & Internet
Why my dvd /cd not work properly , in hardware it show the it is woorking properly , but if i put any cd and insert it then after its not read the data in cd
Does the led on the dvd/cd drive flash after you've put in a disk? Go into "My Computer" and check that the drive is indicated there. If it isn't, then you would need to check the drive connector inside the computer to make sure it is connected properly and that it is not loose. If the drive is indicated in my computer, try another disk, perhaps a music cd, and see if the drive reads the disk. If it does, that tells you that you may have some defective disks. If the drive is detected in my computer, and no disks are read by the drive, then I would assume the drive is defective and replace it. Good luck!
Jan 24, 2011 | Computers & Internet
Dvd icon is shown but does not reads CD/DVD
If you have CD-DVD burning software uninstall it and restart the computer.Open this link and click on run now http://support.microsoft.com/kb/929461
Restart computer again and check
Jul 29, 2010 | Samsung SHS223B DVD┬▒RW Burner
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
CD/DVD TS-L632m ATA Device Doesn't read CD or DVD
Step 1: Unplug the power code from the Drive and start you PC and let it boot to windows without the drive.
Once Windows is up and running.
Step 2: Shutdown the PC
Step 3: Connect the power code again to the drive and then run you PC.
This should fix your problem
Mar 08, 2010 | Computers & Internet
My computer is slow and the is not reading or burning CD/DVD
Slow computer problem would be different then that non reading disks. Slow computer could happen in many cases, a virus is taking up all the memory, or defragmented hard disk, programs that required more memory and cpu speed. CD, DVD could fail to read due to loose cable, BIOS setup or damaged drive.
Sep 16, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
My dvd combo does not read dvd
There are separate lasers for CD reading, and for DVD reading. This is why it is possible to have a drive that reads only CDs but not DVDs, or the other way around. And your particular combo unit seems to have a lot of these problems. Since the drive doesn't work it's almost definitely a problem with the drive itself (I'm assuming that there is nothing wrong with the discs you tried to read). If that drive is still covered by a warranty period, send it back for repairs. Otherwise, I can't see the harm in trying to tinker with it yourself as the DVD portion of it is dead anyways. Ummm, on a side note...CompUSA is going out of business and they are selling things cheap. I got a DVD lightscribe burner for $40...booyah!
Mar 26, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Sony DRU 700A, can't play/write DVD
go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive Good luck!
Oct 28, 2006 | Sony Dual layer (DRU700A) DVD±RW Dual...
Gateway MX8711 Notebook Logo
121 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
