Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
I was kneading dought with my professional 600 and it stoped all of a sudden...there is a smell from the moter
  • 44 Answers
When the kitchenaid overheats when mixing dough many times its just the thermister that has blown. This part is available from radio shack for about$1. 125v 135-150 degrees. just repace it and you may be in luck. the thermister acts as an overload fuse when the motor get bogged down and overheats instead of the motor blowing the thermister blows to protect the motor.
Posted on Dec 10, 2008
Kitchen aid mixer overheated
Most of the time this will not be an immediate problem. Let it cool down and do not over work it again. Continuing will eventually burn out your motor and require replacement.
Nov 12, 2013 | KitchenAid KSM50PR Professional Series...
My preeti lavender stopped workng suddenly
If its new, I would return it for warranty.
Dec 31, 2012 | KitchenAid ProLine 600 Stand Mixer
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Bevel gear and worm follower gear no longer stay together
they should be a tight fit as the clip is just to help retain position
if they are ment to be loose replace the clip and inspect the groove for the clip as the edges may be worn to a taper rather than a sharp edge which will allow it to be moved out under load
May 18, 2017 | KitchenAid KP2671 Professional 6 Series...
KitchenAid® Professional 600? 6-qt. Bowl-Lift
nice machine!! enjoy using it. I assume you have no problems with it since no problems are described!!
Feb 11, 2011 | KitchenAid KP2671 Professional 6 Series...
I have a kitchenaid 600 professional stand mixer. I was told that you can only use the dough hook with setting 2 for only 5 minutes. What do you do for recipes requiring a longer time for kneading? Is...
You can knead longer than that, but you run the risk of over heating the mixer because at that point the dough is very firm. Your best bet is to knead it by hand.
May 14, 2010 | KitchenAid KP2671 Professional 6 Series...
I have a KitchenAid 600 professional stand mixer. I was told that you can only use the dough hook with setting 2 for only 5 minutes. What do you do for recipes requiring a longer time for kneading? Is...
It is a matter of overheating. I have used the same mixer for 8-10 minutes, then put an ice pack on the gear head. The problem is that they cheapened the gearhead in the newer models by using plastic gears. The older ones with metal gears didn't have the same problem, however they put the warning on all models to cover their butts . . . .Just fill a zip lock bag with ice and lay it on top of the gearhead before and during use and you can runit longer without overheating and melting the gears.
Mar 26, 2010 | KitchenAid KP2671 Professional 6 Series...
While kneading bread my mixer suddenly starting hanging up at the back side. It makes the full circle but when it gets to the back it stops and "hums" and then sometimes will go on but most of the time...
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear"
Feb 01, 2010 | KitchenAid KP2671 Professional 6 Series...
Beater jams
You are going to DESTROY YOUR MIXER by kneading dough with the flat beater. Read the directions. They spell it out in big letters. Only use the dough hook for dough; only use speed 2.
If the mixer generated enough torque to knead dough with the flat beater (it doesn't), it would tear up and overwork the dough. As it is, you're lucky you didn't strip a gear.
Dec 23, 2007 | KitchenAid KP2671 Professional 6 Series...
Motor is not running now
Im a service tech for hobart and repair these mixers often-is it worth repairing the unit?YES it is.I have never seen a motor burn up on these units,i have seen keys sheared and gears broken but thats the extent.There is a overload/reset button that sits on the back of the mixers pedistal,if its tripped when you push it in it will click.when these units need service it is usually from overloading the unit with too much product.Any other questions let me know.
Nov 30, 2007 | Hobart N50 Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
369 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
