Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
HLN5065W When I have the TV on for about 10 minutes the picture will Freeze and look like a film negative in black and white. it will become inoperable requiring me to unplug from the wall for approximately 30 minute and will work again for 10 minutes and happen again. The light on the front will blink red at the same time until power has been disconnected. Appreciate any help you may have. I have replaced the larger fan that exhaust the heat from the lamp blub assuming I put it in correctly(as an exhaust verses air blowing onto the bulb)
  • 505 Answers
There are 3 leds on the front that blink the error code. which leds blink gives you the error. if its just the standby/temp red led blinking, it has overheated for some reason. there are a couple other fans you could clean but check your ventilation. many people put too close to the wall or close it up in a cabinet. it needs atleast 4" from the wall and someway to vent out hot air and get cool air in. a different model had the temp sensor cause this issue, it is the silver thing right atop the lamp. you will have to pull the whole back panel possibly, there are two wires that hook to it and two screws holding it to the engine (lamp housing). if you get lamp and temp leds blinking, reseat the lamp door. timer and temp leds is a fan error, all 3 leds is a lamp error (lamp, ballast, colorwheel, dmd)
Posted on Dec 08, 2008
I have a problem with a samsung model hln5065w 50"
it is due to more heat generation in ur board .i will cause serious accidents so repair it fast.
Nov 22, 2010 | Samsung HLN5065W 50" Rear Projection...
I don't know how to buy film for this camera. is it just 35mm 400 film
Yes, you can get 35mm in color negative or black and white. Although the black and white film may be in 2 varieties: traditional process black and white(not all labs can process this) and C-41 process black and white (and one hour lab can process this). If you are looking for color film choose the C-41 color negative film like Kodak gold 400 or Fujicolor 400.
Mar 28, 2010 | Nikon N65 35mm SLR Camera
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W only displays black & white picture
Hello,This problem denotes a defective color wheel, I would not suggest that you attempt to change it becuse of the risk of causing more damage. I would advise that you have the Tv repaired by a qualified TV technician, due to problems I have seen when repairing sets like this due to improper reinstallation of the color wheel.I hope this helps,Thank you,Shuttle83http://www.electron-age-technologies-llc.com
Jun 06, 2009 | Samsung HLN5065W 50" Rear Projection...
My Samsung HLN5065W started to freeze to a black and white
I have a problem with my HLN 5065W Samsung DLP that 3 other folks have and no solution. After the set is on from 5 minutes to 6 hours, the screen will freeze in black and white, I can turn it off for 5 minutes and it will display a good picture again. Sometimes the screen will just go dark blue, TV has to be cycled on/off to get the display back. This problem is getting worse, started as once a month, now 3-5 times a day. I have a tech background and can read a schematic, HELP.
Mar 01, 2009 | Samsung HLN5065W 50" Rear Projection...
HLN5065W picture turns black and white and shuts down
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. This is a known issue in this TV! Expect to spend $300-500 to have this serviced by a service company. If you have the right stuff, you can do it yourself. If you search the web, you'll find a color wheel for this TV for under $100, but installation can be tricky.
michtech
Feb 16, 2009 | Samsung HLN5065W 50" Rear Projection...
Tv freezes white and black negative image
Yes the digital board is the culprit. I need the complete model number so I can get you the correct part number. On the right hand side of the TV is a sticker with the model/serial and sometimes a version number. Get me all those and I will look up the part number.
Mar 18, 2008 | Samsung HLN5065W 50" Rear Projection...
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
270 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
