Question about Refrigerators
Replacing a relay switch/kit on a maytag refrigerator MSD2432GR
Our fridge quit cooling, we came home to water all over the floor, it was the ice melting. We cleaned out the back got all the dust out of the coils etc... We were told that if we checked the relay switch and it rattled, it was probably what went bad, We removed the part and went to the part store and purchased a replacement. The replacement is in pieces (the original part came in a white box) We figured out how to put the two pieces into the fridge but are totally confused on the wiring. We have the instructions that came with the part, but they are confusing and we just can't figure it out. The man at the parts store said it is the right part, but the configuration is different.
The model number on the Maytag fridge is MSD2432GR Serial number starts with 129. The compressor is number EMBRACO The part we purchased is Overload relay kit.
Again we know how to put the two pieces into the compressor but the wiring isn't matching up or making sense. This is what is confusing us. The instructions say exactly this: ''White jumper wire on left terminal, (number 2 on relay) into 3/16 terminal on old harness''. What does that connect to? The guy at the parts store said the jumper wire may not be needed And the second thing that is confusing us is exactly this: ''Orange or white wire to right terminal (number 3 on relay) PTC Start device''
Can the orange wire and the jumper wire be hooked together or not?
Can you help explain this for us? Thanks for your help.
  • 2 more comments
  • Griff96 Dec 05, 2008
    One more question we have - what does the phrase "old harness mean?"
  • Griff96 Dec 06, 2008
    Thanks for your help. I scanned the instruction page and can take photos of the parts if you need them.
    Here are the parts.
    Here is the compressor
    Scholar:
  • 82 Answers
Wow! I am confused also. It sounds like it is more complicated than the ones I use. Can you send me an image of the relay and the terminals on the compressor?
I can tell you that the live wire ( wire with electricity) is the one that goes on the common terminal, that is the one that it at the top of the trangle formation, unless the formation is upside down then it goes on the bottom. Then the other neutral wire goes on the run terminal which is usually on the right if the triangle formation is right side up. Usually the neutral wire is white. So
try putting the white wire on terminal 3 and the orange on the top (or bottom) terminal. If there are any wires left over that you think need to be connected I would need to see an image.
Posted on Dec 05, 2008
  • 2 more comments
  • Shane Hays Dec 06, 2008
    I am sorry. I ment an image of the part itself and the compressor. The image you sent is too small and hard to read.
    Ok Great pictures. The white part goes onto the top or bottom terminal depending on its orientation. Then the black on the other two. The tricky part is trying to find out which wire is "live" . It looks like the power cord is unplugged at the harnes. If that is the case the harness might line up with the cord and you can tell that way. In order to do this you need to follow the power cord to the wall. The prong that plugs into the right side of the outlet is the "live" side. Follow that side to the harness and see which color wire lines up with it the orange or the blue. This is the one that will go on the common/top/bottom terminal. The other one will go on the black part. Also, it looks like you won't need the jumper wire.
    To be honest with you I am not sure. They may be talking about the wires going to the compressor.
    Also if this doesn't work I really need to be able to see all of the terminals on the relay and the compressor.
I have water leaking under freezer side of door. I turned the ice maker off, turned off the water to the fridge, cleaned out the ice behind the panels, and put it all back together. Every couple of days I...
Hi, The drain hole is plugged with debris or ice...
Just had to thaw my own out tonight, it was doing the same thing... Take the bottom draw out and maybe the bottom shelf and then you will see the ice buidup in the back and on the floor... Thaw it out and make sure the drain hole is open... then you will be okay again...
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 25, 2011 | Maytag MSD2651 HE Side by Side...
The ice dispenser and water dispenser on the door will not work
"Prepare for the worst" This is a problem i'm currently dealing with at the moment, ice maker thaw'd and refroze the ice as a block, binding the crusher turbine till it quit working. then water dispenser started spitting till it quit working, but anyway i disconnected the ice maker and water dispenser power hookup, because when i tried to use it it was drawing off the power of the fridge. now i'm to the point where fridge clicks like the relay is going out. in the back of the freezer below the ice maker tray i removed the clip or screw to where when it clicks i can hand spin the cooling fan on the click, and fridge starts up and runs, but don't remove this panel because having it on helps the air push into fridge compartment and keeps cooling elements from turning to a block of ice, " so long story short " its either your cooling fan or relay on chip board that starts cooling fan, i'm no expert but this is where i'm at hope it helps.
Jan 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have ice on the bottom floor inside the freezer and. water on the floor outside by the front of the freezer door on the hinge side
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
I HAVE 25.6 WIDE BY SIDE CAME HOME ONE DAY AND THERE WAS WATER ON THE FLOOR IT STILL COOLS VERY LITTLE BUT WILL NOT FREEZE
I had a similar problem on my kitchenaid refrigerator a few months ago. All it took was replacing the compressor start device relay and it started working again.
Jul 24, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice built up floor of freezer compartment. water on floor
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 09, 2010 | Maytag MZD2766GES Side by Side...
My Maytag side/side freezer not cooling. Motor is running. Woke up this morning and water was on the floor. What can I do? Please, we're moving and this just happened. Its only 4 yrs old
your condenser fan is running,but the compressor if its quite warm to the touch isn't,its running on both start and run windings and will burn out the windings over time if left like this,you need to replace the ptc overload relay combo on the comperssor and the unit will again cool properly
Mar 19, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerators Logo
3,196 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
