Thermostat set at 71 deg overshoots to 74 deg
  • Anonymous Dec 06, 2008
    the thermostat that over shoots from 71 to 74 is honeywell T8865A Chronotherm (wireless).the heating system is steam.
  • serco 2000 May 11, 2010
    What king of heating do you have?
    Novelist:
  • 124 Answers
If its a mercury bulb stat it must be perfectly level. or it will overshoot or under shoot depending on which way it is out of level. the heat anticipator under the cover if its an older stat should be .4 to .6 or it will over shoot. that is what lets it know that by the time it shuts off burner or strips and cycles down the fan it should be at the desired temp. if its digital be sure the hole in the wall behind it is sealed 100 percent. even a little cold or warm air leaking into the back of the stat can cause faulty readings and over or under temps. if this doesn't correct the stat itself may be bad and in need of new. good luck.
Posted on Dec 05, 2008
We have a Duo-therm by Dometic thermostat that does not shut the ac off. We have to manually shut thermostat off to shut ac off. Any suggestions what we can try or just replace thermostat?
Try plugging the hole in the wall where the wire comes through. Also be sure you are not trying to reach your humidity set point therefore overshooting your cooling setpoint. Referred to "droop" in settings
Jun 01, 2017 | Dometic Heating & Cooling
When in the heat mode the system will start and rune only a few seconds then stop. After a short pause the system will re-start and run ubitl the set temp is reached
Bruce, what you may be hearing is a short cycling of the fan and not a short cycling of the system. The fact that you indicate it only does it once per cycle kinda suggest that. If the ENTIRE unit was shutting down, it could indicate an adjustment in the 'heat anticipation' circuit on the thermostat sub-base was required. The heat anticipator is an adjustible resistor on non-digital thermostats that warm the spring that rotates the mercury bulb to cause it to shut off just a little bit before attaining setpoint...thus 'anticipating' the shut down temp and not 'overshooting' the setpoint.
Too low of a setting and the system will short cycle, too high of a setting and the system will overshoot the setpoint. The typical setting is .4 amp which is where the majority of sub-bases are set at from the factory.
Nov 12, 2015 | Hunter 44860 H Univ. Touchscreen...
I have a White-Rodgers programmable thermostat. I have it set to go to 74 degrees at 11:00 PM. It has started going to 74 at between 10:00 and 10:30 PM. If I press run it goes back to the daytime temp...
Hello I assume its cooling program.Probally the thermostat has a recovery mode.In another words the thermostat will come on EARLY to make sure you are at (74*f at 11:00).Maybe try 11:30 start time and see if that helps or disable energy recovery mode.
Jun 17, 2011 | Heating & Cooling
My round Honeywell T-87 on the main floor(middle) of the house has no ON/OFF switch. It controls the temp of that level of the house and even though it is set at 60, the temp is way too high and reads 74....
What you are describing is the Heat Anticipator. It is a small resistor that helps the thermostat from overshooting the set temperature by heating up and shutting off the thermostat just before your set temperature. I don't think that is related to your over heat. 14 degrees is a lot and the Heat Anticipator will only effect it 4 or 5 degrees. I would remove the thermostat and check if there is a call for heat. If so, you have a shorted wire. If not, replace the thermostat.
Dec 30, 2009 | Honeywell Programmable Thermostat Heater
Hi, Power surge knocked out power briefly, but now we are getting no printed confirmation sheets that fax was transmitted. How to reset??
Press
Function
74
set
12
set
set
stop
To reset date and time press'
function
71
set
enter date and military time
set
stop
Oct 22, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Thermostat set at 74, but air conditioner won't turnoff
Need to reset the lever sensitivitie( behind the cover) to a lower setting.
Jul 22, 2009 | Honeywell Heat/Cool Thermostat
1998 honda civic cel code 71-74
code 71 means #1 cylinder missfire 72 Means #2 cylinder missfire 73 means #3 cylinder missfire and 74 means #4 cylinder Missfire
May 29, 2009 | 1998 Honda Civic
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
