Question about Canon Office Equipment & Supplies
Canon IR 3300 ADF problem with image verticle compression of print on PDF and does not happen on when using flat bed.
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Posted on Apr 20, 2009
  • 39 Answers
SOURCE: can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
  1. Choose File > Print.
  2. Click on Advanced.
  3. Choose Postcript Options.
  4. Under Font and Resource Policy, select "Send for Each Page".
  5. If "Print as Graphic" is checked, it must be unchecked, as well as "Send As Group" if it does not uncheck itself when you select "Send for Each Page"
  6. Save it as a custom configuration.
Posted on Oct 06, 2009
hamzaskilltd
  • 316 Answers
SOURCE: error code e000002-0000 canon ir 3300
fixing assembly low temperature
Posted on Jun 26, 2010
  • 149 Answers
SOURCE: I HAVE A CANON IR
WHAT: Either the main thermistor doesn't attain 30?C 1 second after the power switch is activated or it doesn't attain 70?C 2 seconds thereafter.
WHY: It has a faulty fixing film unit, lack of connectivity with the main thermistor, lack of connectivity with the fixing heater, a faulty main power supply PCB, or the DC controller PCB is faulty.
NOTE: You can reset the error by performing the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
CONNECTOR FIX: Make sure that the connector of the fixing assembly is seated.
A. main power supply PCB (J8) relay connector heater
B. DC controller PCB (J320) relay connector thermistor
FIXING FILM UNIT (THERMISTOR) FIX: With a multimeter, check the interval between pin 1 & pin 2 & between pin 3 & pin 4 of the connector (4-pin) of the thermistor for electrical continuity. A result of ?? means that the circuit is open (lack of connectivity). Resolve this by replacing the fixing film unit.
MAIN POWER SUPPLY PCB, DC CONTROLLER PCB FIX: Press the Start key. If the drive voltage of the heater is supplied by the connector J8 of the main power supply PCB, then the main power supply PCB should be replaced. If not, then the thermistor control mechanism is faulty & the DC controller PCB should be replaced. Use the following to ascertain this:
Main heater: between J8-1 (FSR1) & J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) & J8-5 (FSR COM)
Posted on Sep 25, 2010
Canon ir 3300 printer has dark part in page not apper in print what is problem
dear
If the dark portion of the page is out side of the image scanned, then there may be chance of light passing to the scanner through platen glass.Pl. check the top cover and whiteness of the flap.
If the scanning through the PC has the same problem then the SHADING adjust to be done.
Thanks
Feb 21, 2015 | Canon Ir 3300 B/w Copier image Runner...
Canon IR 3300 PDF file slow printing
you cannot do anything with it
it also happens in my machines
Apr 05, 2014 | Canon FAX JX200 Fax / copier Plain Paper...
Ir 3300 adf side lines cut
plz clean ur adf platen glass and after
ones u start u feedare cleaan
Oct 23, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Have Cannon image runner iR 3300. It is networked to our computer. It prints some pdf files and some of them it doesn't print.
This is probably a Adobe problem, but i might know how to fix it. When selecting the printer you want to use in Adobe reader, press the "Advanced" button at the bottom of the window. Press the "Print as picture" box. This should probably fix it.
Nov 12, 2010 | Canon imageRUNNER C3220 Color Copier
What does error code E0002020001 mean on a Canon IR 2200?
check the platen glass & adf scanning Glass is proper
That mean white plate error.
May 06, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Image moves 2 " down when printing through adf in only legal size
Enter service mode > additional functions 2 8 additional functions >select feeder > funtion tab> set adf guides to legal settings > select TRY-LGL on the lcd display> select ok>
test if not corrected
then
select adjust> DOCST > use keypad to set adjustment value> select OK
select LA-Speed> use keypad to set adjustment value> select OK
Remember to write down the original values before changing them in case you need to set them back.
Jul 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Ir 3300
Set print settings to print as image. Also make sure to spool printing.
Sep 19, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
252 people viewed this question
old marine
old marine
