Question about Sony Playstation 3 (PS3) Console
Message saying its too hot and it turns off automatically
Although its only been turned for a few minutes if you can help it would be grateful
  • s_toner Dec 08, 2008
    no this didn t help, i cleaned all the vents and still nothing
    its just out of warranty too but none the i ll get in contact with sony thanks for your help
  • 903 Answers
Make sure that the unit is in an open space where it is free to breath. Also check that there is not a build up of dust on any outlet vents etc....
I hope this helps
Posted on Dec 05, 2008
  • Debs
    Debs Dec 08, 2008
    okay then the problem sounds like it could be coming from inside the system itself, like a faulty fan etc.. especially if you know that it is not overheating. Contact sony and they will probably ask you to send the unit in for repair. (if still under warranty the should replace it)
My fedder azhp12d2a portable air conditioning unit will not turn on, the light above where it says "built in three minute cooling delay" is blinking red continuously. When I plug it in it beeps and...
every time when you turns your ac on it takes 3min , dear it is just a time delay to protect your ac comp , it is not harmful. You can by pass it by pressing turbo key in remote aur by switching off your ac by remote only not by mains. it is helpful , try it
Oct 14, 2013 | Heating & Cooling
Repair tv
You didn't say anything about the model or make but a lot of times this comes from bad capacitors...try this...on the open fins on the back of the TV, try putting a blow comb on there and set it on low and leave it there for about 3 minutes, turn the set on and see if it comes right on, if it does there are bad caps on the power board, it could be replaced or you could repair it yourself for a couple dollars
Dec 17, 2017 | Zenith R56W36 56" Rear Projection...
My phone keeps saying that i have a message but when i check the message there is really no message. how do i fix it
Try reseting your phone, turn off your phone and take off the battery few minutes.
The message warning must deleted, if not, try contacting your local phone service.
Hope helps.
Feb 14, 2012 | Cars & Trucks
I have a 2000 Dodge Ram 1500 that will blow cold and hot air for only a few minutes. After that is only ambient air temps. It is a 5.7 ltr, automatic with only one set of climate controls. The heater core...
you say it will blow cold and hot air for only a few minutes. You don't say but I assume you mean will blow cold a few min. when turned on AC max , blow hot only a few min. when turned to heater hot. Assuming thats the situation and you say AC charged and shows good on the low side -you should charge the AC to a full charge on the low side will cause problems with the AC air compressor kicking on and off. I suggest while the engine is running and turned to AC cold max watch the AC air compressor clutch to see if it does indeed kick on and off if so charge completely. As far as the heater make certain you coolant is all the way to the top and the best way to do this is when engine is completely cold remove radiator cap and fill completely and completely close cap then fill overflow container just to the cold level. That should fix your problem.
Sep 06, 2011 | 2001 Dodge Ram 1500 Truck 2WD
WHEN I TURN ON THE CAMCORDER IT SAYS DEW
Hi, dew mean its the humidity sensor is on
thats lock all operation/ you can try an air dryer
:/open the loading tray if you can and blow at medium hot ,some hot air in slot for mechanism for few minutes avoid to be to close off the pastic cassing
and leave it rest for a few minutes and try it...
if wont work that is the dew sensor it self defect
hope that will help
Mar 29, 2010 | Sharp Viewcam VL-Z1 Mini DV Digital...
Automatically shutting off after about 5 min
dose it have a thermostat if it dose that will turn it off
Jun 24, 2009 | Comfort-Aire PAD-91 Air Conditioner
Iam switching my ps3 on and after a few minutes a message on the top right hand side say your computer is to hot please switch off for a few minutes and try again.
right. i have heard this problem a few times and quite often it can be attributed to either a blockage of the cooling fan, thus causing it to retain heat, or the cooling fan may not be functioning fully or at all. this is bad as exactly this message will appear, although the ps3's fan may take some time to get going properly if you have an older system which means that all you need to do is leave it and it may calm itslef down. otherwise there is really not much you can do other than make sure it is not covered and there is room for the air cooling intake.
May 04, 2009 | Sony PlayStation 3 40GB System
Nokia 5200 - delivery report
you have to cheche thwe message setting of your phone, go to messages- message setting- sending profile- common and turn off the delivery report option, thats it.
May 07, 2008 | Nokia 5200 Cellular Phone
Sony Playstation 3 (PS3) Console Logo
109 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
