Question about Sony Playstation 3 (PS3) Console
I think the laser is going out?
The player will attempt to read the disc but will not play I have been told by Best Buy Stores that the laser could be going out or the lens has a problem. Who would I send this too and what would the costs be to correct this problem?
Sincerely,
Linda Wells
I agree with mumma on resetting the system before you spend money to get it fixed. backup the data you want to keep. then try this.
1) (make sure your controller is plugged in) and press and hold the power button, turning the system on. you will hear a beep as soon as you touch it, then another beep after 5 seconds. keep holding the button and you should hear two quick beeps (not three, if you hear three, try again). as soon as you hear the 2 beeps release.
2) you should now be at a screen that has 6 options. click on restore file. it will tell you your files are corrupted, but that shouldn't be all that surprising.
3) click some yes's and let it do its thing. this may work, it may not. but it's worth a try before you pay money. (you can do this before or after you reformat your system and start from scratch, up to you)
Posted on Dec 05, 2008
  • 903 Answers
Http://www.sony.com/
you can try the link above for support for your console. The only other thing that I can suggest is that you reset your system and see if this makes any difference. Sometimes certain games can make the system act weird. If you don't mind losing saved data then I suggest restoring it to the factory default settings first then if you still have the same problem after it could be the disk drive itself. If restoring your system does not help then contact sony on the above link for further support and advice.
Also you did not say whether this happens with all of your disks or just some. If it is only some of them, then the disks can be cleaned with a little white spirit followed by drying gently with a soft cotton cloth.
I hope my advise is of some use to you
Pdm-2727 portable dvd player
Hi there
I think your DVD Player could have been damaged while it was in storage, this sounds like there is a problem with the lens (laser), i am going to suggest that you take it to a repairman and ask him to fix it or buy a new laser for your DVD Player attempt to fix it yourself.
If your DVD player is still under warranty, you should take it back to the retailer and have it repaired or refunded.
This could also be caused by "un-married" Player and Disc, if you bought the DVD Player in one country and bought the DVD's in a different country, this could also cause the problem. If the DVD's are copied, that could also cause it.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 5692f33.png if it helped you.
Kind regards
Dustin Ellse(BearWeb)
Jul 03, 2008 | Polaroid PDM-0711
I have made several attempts to play a disc on my JVC TH-V70. IT reads 'reading' on the dvd unit then after a few second the disc ejects. Why is this happening?
Hi Adrienne - If it only happens to the one DVD it is most likely a problem with the DVD being damaged or dirty.
If it's happening with all your DVDs your player laser lens is probably dirty or it might be damaged. If no discs are being read get yourself a CD/DVD cleaning disc and run it a couple of times (following the directions). Of this doesn't work you will have to decide if the player is worth the price of a repair (unless it's still under warranty). Most aren't as you can buy decent players for less than $50. Any repair will cost at least that.
If it is the one disc I suggest you take a clean soft cloth and wet it slightly with plain water and the give it a few strokes across the disc (not in circles), let it try dry for a few minutes and try it again. Also examine the disc (bottom) for any obvious scratches or stuck on gunk.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 28, 2011 | JVC TH-V70 System
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
I place the dvd in the holder, and it closes, but does not play. It says loading and then nothing. please help.
Tries the tv DVD player,play it with many other DVD discs too?Some the disc u trying to play it might just be bad like the reading shinning laser surfaces are scratches,smushes or grims and dirts on the disc reading surfaces?Tries washes the DVD disc,with some dish washing liquid,dries it with a cloth wait like two mins.Try the DVD disc again.If it have problems,but all DVD discs or with many other DVD discs too?Tries websites like Ebay.com or Amazon.com buy a Disc cleaning kit put Disc in the DVD player to play it have 50/50 chances to clean the DVD player laser eye reader.If not more like the DVD player laser eye it is dead.Tv still work fine?Don't take the tv aparts,tries to clean it laser eye manally,because,if u putting tv back together again might causes tv problems too.Just buy a DVD player unit plug it in the tv and play ur DVD Discs.DVD player extenal unit it very cheap these day.Don't take chances,like take ur tv aparts.
Feb 12, 2011 | Naxa Electronics NX-542 13 in. Portable TV
The CD player will no longer recognize or play discs - or it takes ages to engage and play the disc. I think the laser is warn out. Is it replaceable, and is it cost effective to do this? Thanks, Ralph
I have the c521i with similar problem. It will play discs most of the time and sometimes can go for an hour or more before hanging up. Sometimes the disc is spinning and the laser is moving up and down (clicking) trying to read data. Sometimes the disc will stop spinning.
The replacement laser mechanism is a Sony KSS-213C and can be found by a few resellers on ebay for between $10 - 26, and also online at stores like MCM Electronics. This assembly has the laser head, gears, everything that needs to be replaced. I should get mine in the next few days. I also bought the 16 pin flex ribbon cable that is about 8 inches long that connects from the laser and goes into the circuit board. With basic DIY skills, this is a simple fix. A little care and effort is required on the laser assembly. I am told this will fix and will report back as soon as I get it installed and can verify it works.
Jan 01, 2011 | NAD C521 CD Player
If we place in a disc or a dvd disc it doesnt play and shows no disc, when ther is a disc., what could be the problem??
The DVD player the laser eye have problems.The easiest way to clean the laser eye is to buy a DVD player disc cleaning kit.Tries stores like Radio Shack,Walmart,Target should have this product.
Oct 18, 2010 | LG Televison & Video
Hi. I recently bought a Sony CDP-CX355. Until a few days ago it was working fine. Suddenly, the player stopped reading the discs. It grabs a disc as if its going to play it, but just reads it, and then...
This happens when your laser is not able to read the data of the disc. Either u are using disc which the player cannot read or the disc is not readable. If your CD player is not reading the discs which it used to read earlier then CD player laser head has to be replaced.
Aug 14, 2010 | Sony Audio Players & Recorders
DVD player not playing DVD's
Yes. The laser lens in your player is dirty or failing. To fix your problem, try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail stores.
Nov 30, 2005 | Samsung HT-DB120 System
Sony Playstation 3 (PS3) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
