Question about Kenmore 64902 Electric Dryer
Kenmore Dryer works for about 20 MINUTES, not seconds
My Kenmore dryer (4 to 5 years old) starts fine, heats fine, and then quits after about 20 minutes. When we try to turn it back on, the start button just buzzes. We have to wait about 30 minutes to get it to come back on, and then the same thing happens. Is this the same problem as the person whose dryer stays on 20 to 30 SECONDS, as opposed to my 20 to 30 MINUTES?
  • 1 more comment
  • Anonymous Jun 18, 2008
    it works for about 10 mins, shuts off. Have replaced hose and cleaned out exhaust, removed back vaccumed to no avail.
  • ramanuskas Apr 09, 2009
    exactly the same problem. Cleaned out but still stopping
  • Anonymous Mar 28, 2014
    The cycle was going, about 30 minutes in, it just quit. No problems or indication of any problems previously
    President:
  • 878 Answers
SD, doesn't sound like the same problem. Yours sounds more the like motor kicking out on overload and when it cools down you are able to start it again. The thermal fuse and high limit TCO are non resettable so you can rule them out. You are going to have to check some things out. Make sure the rollers and pulley are not binding. The blower wheel is not binding. These things will cause a drag on the drum and put a heavy load on the motor. Catriver...post back
Posted on Feb 12, 2007
I have a 70 series Kenmore dryer model # 66722694 it heats fine and runs fine but it cuts off for no apparent reason. after letting it sit or cool down for 15 to 20 minutes, it starts back up. i removed...
sounds like you have a bad heat sensor bypassing your fuse is an open invation to start a fire its there for a reason it also sounds like your timer is bad you might consider a new dryer dependimg on how old it is
Jan 19, 2011 | Dryers
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Kenmore Gas Dryer is 7 years old. It will heat up
Replace the gas valve coils. Common problem after 3-4 years.
Jul 05, 2009 | Kenmore Dryers
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
Nov 27, 2007 | Kenmore 73952 Gas Dryer
Kenmore 64902 Electric Dryer Logo
149 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
