Question about Beko 24 in. D3421F Free-standing Dishwasher
Beko washing machine fills with water when not in use!!
After a wash cycle, the water drains away and everything seems normal, but after 15 minutes the drum starts to fill with water again. Ive checked for blockages but none are apparent
    Scholar:
  • 123 Answers
Hi there.....you got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Posted on Aug 23, 2009
  • Jim Gallagher Aug 27, 2009
    Hello..this fault is most likley due to a faulty water inlet valve...this is the actual valve on the machine (where the fill hose screws onto the machine)...when you complete your next wash turn the water to the machine off.......check your machine in 30 /40 mins....there should be no water in the drum indicating that the water inlet valve needs replacing....turn the power off and remove the top of the machine...turn off the water suply and remove the fill hose from the machine...mark and disconnect the wiring from the inlet water valve....twist the valve either clockwise or anti clockwise to remove it.from the machine...replacement is just the reverse......this will solve the problem
    regards Sir Galahad
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
Hoover 500mb washing machine doesn't 'click' through the cycles
Sounds like your timer is not working correctly. I would suggest replacing it, as there isn't a way to repurchase timers.
Oct 10, 2015 | Hoover Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Oct 30, 2013 | Beko Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Wash machine won't fill
Here is a tip that will help you...
Water will not stay in Washing Machine
http://www.fixya.com/support/r4696322-water_will_not_stay_in_washing_machine
heatman101
May 23, 2010 | Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Beko 24 in. D3421F Free-standing Dishwasher Logo
227 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
David Payne
David Payne
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
