Question about HP OfficeJet 6210 All-In-One InkJet Printer
Need to change date
I need to change the date on my HP printer
    Novelist:
  • 159 Answers
Http://www.hp.com/#Support
Select: See support and troubleshooting information
Type in your model name
A manuals link will appear
Posted on Dec 05, 2008
When installing new printer cartridge, the install date is wrong.
please change the printer date and time setting in going on setting menu.
Sep 25, 2015 | HP Photosmart C7250 All-In-One Thermal...
Need to change the time on officejet 6210 All In one.
Here is the link to the User Guide if you need it. Page 88 of the PDF gives step-by-step instructions for changing the time on your printer.
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
Mar 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
HOW DO I CHANGE THE DATE & TIME , HP Officejet 6210 All in one
Hi
you can change it by pressing menu
and with arrows get to setting
there you will find date and time
and if you want to refill it easy check here how
Jan 17, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do I change to the correct date and time on the HP Offfice Jet all-in-one J5780 printer?
Press on the Setup button on printer front panel
Use arrow key till you find TOOLS - Press OK
User arrow key till you find Set Date and Time - Press OK
This way you can setup date and time on your printer.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 14, 2011 | HP Officejet 6310 All-In-One InkJet...
How do i change the time and date on my hp officejet 6310 printer
First of all, congrats, you are using one of the best printer on the market.
For HP Officejet 6310 :-
To set the date and time
1. Press Setup.
2. Press 6, and then press 3.
This selects Tools and then selects Date and Time.
3. Enter the month, day, and year by pressing the appropriate numbers on the
different order.
4. Enter the hours and minutes.
5. If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the display.
And, you can also download it's User Manual from :-
http://h10032.www1.hp.com/ctg/Manual/c00633922.pdf
Sep 19, 2010 | HP Officejet 6310 All-In-One InkJet...
The date showing in the printer window is an old one. As a result, the printer is not working properly. How do I change it to make the printer work correctly?
Here's a direct link to the printer's reference manual:
http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
On page 41 of this PDF file, you will find the section "set the date and time". Follow the instructions to set up the date & time of your printer.
Dec 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 5550 print cartridge light flashing.power light on,not flashin
All HP ink cartridges are dated. If you are using the remanufactured ones the date is not changed and will not work properly at all. By HP ink only and you will never run into this again.
Sep 03, 2009 | HP DeskJet 5550 InkJet Printer
HP Officejet 9110 empty or expired cartridge error
You were a bit vague in your report as to what the exact error is that you are plagued with. Perhaps you have more than one. The 9100’s ink cartridges are “smart cartridges.” They each have a chip in them that reports various cartridge statuses directly to the printer. Diagnosing the problem correctly requires the identification of the particular error message. You can find a list of the error messages and what they mean here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=376170&prodTypeId=18972&prodSeriesId=376170&objectID=c00067620
I think that you are experiencing an “INK CARTRIDGE EXPIRED” error. This error is not related to the ‘volume’ of the ink within the cartridge(s) but rather to the actual expiration ‘date(s)’ on the cartridge(s). The expiration date is encoded on the chip that resides on the cartridge. The actual expiration date appears to relate to the date two years after the date that is stamped on the cartridge label. I can’t change the expiration date on the chip—at least not easily or inexpensively—but I have discovered a way around it.
The date on the cartridge corresponds to the date on the printer itself. You just need to send the printer back in time to a period before the expiration date and you should be able to print again. A time machine is probably out of the question. Instead, reset the date on the printer to reflect a suitable date.
This could conceivably have some negative consequences that I haven’t experienced yet. I’ve only just discovered this ‘hack’. Though I haven’t tested it, the newly assigned, incorrect date will probably appear on any subsequently received fax transmissions. I can also conceive of networking issues if your printer is networked. Some network related instructions require that all network nodes (all devices on the network—computers, printers, etc.) report a time (and date) within just a few minutes of each other to communicate. You’ll just have to try it in your network and see if everything functions properly or within acceptable limits.
To change the date on the 9100 printer, you’ll need to access the ‘Maintenance’ menu. Just below the LCD panel on the front of the printer there are a series of buttons as follows:
[Return], [Up] & [Down], [Accept], [Left], and [Right]. They each have their own unique symbol, but I’m sure you can understand my descriptions. Press and hold BOTH, the [Up] and the [Down] buttons at the same time while you press and release the [Accept] button—then release the other two buttons. If you weren’t taken directly to the ‘Maintenance’ menu (# 10), then use the [Up] or [Down] arrow button to navigate to it and then choose the [Accept] button to select it. Similarly select the ‘Set date and time’ option, and follow the prompts to make the necessary changes using the appropriate buttons.
Once you have changed the date and time you may have to turn the printer off and then back on again before the printer will recognize the cartridge(s). In my case, the printer went through an extensive print head alignment.
Jan 27, 2009 | HP Officejet 9110 All-In-One InkJet...
How to reconfigure ink cartridge
Change your system date to backward and you can use it again
Oct 23, 2008 | HP Business Inkjet 1000 - Printer - colour...
Change date and time on 6210
Press Setup.
Go to 4
Go to 1
Enter date
Enter time
Press OK
Simple
Jun 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
