Question about Toshiba 46HM95 46" HDTV
Red?Green picture I just replaced the lamp on the Toshiba 46HM95. When I turned on the unit my picture was predominately red and green. Per the owners manual, I turned off the set and removed the lamp, then proceded to replaced the lamp and close the door. Same thing, red/green picture. I have tried adjusting the tint, contrast, brightness, etc....with no change. I called Toshiba and they said to turn off and unplug the unit for at least three minutes so the unit resets to the factory settings. Still red/green picture. What can I do to fix this problem?
  • Anonymous Mar 23, 2014
    after about 20 min of the tv being on the red starts to fade and the tv starts to turn green
    President:
  • 1,284 Answers
If you are connected to a HD cable box or sat. rcvr. using component cables, I would then suspect a loose or bad blue connection or cable. If you have Comcast and have their supplied flat component cable this is a common issue.
Posted on Feb 13, 2007
2 Suggested Answers
premtech
  • 934 Answers
SOURCE: Red?Green picture
You may have inadvertantly loosened a cable connection to the DMD or logic board... You might be able to shut it down, unplug the unit and remove the lamp.. With the lamp out take a good flashlight and shine it into the lamp housing area inside the Tv and see if you have any wire obstructions that you could have contacted with the edge of the housing as you were removing or inserting the lamp...
Bill
Posted on Feb 03, 2008
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Jun 01, 2010 | Toshiba 46HM95 46" HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
I have a tosihba 46hm95
Try replaceing the lamp
Jun 13, 2009 | Toshiba 46HM95 46" HDTV
Led lights flashing
replace the lamp. the lamps basicly have 3000 hours before they go, and also depends on the number of times the unit is turned on and off which greatly lessens the life of the lamp.
Feb 26, 2008 | Toshiba 46HM95 46" HDTV
Red?Green picture
Bill
Dec 18, 2007 | Toshiba 50H72 50" Rear Projection...
Red/Green Light Problem
Had same problem after only 3 months, tech looked at it said had a power circuit problem causing it to keep cycling, they exchanged my TV. No problem since.
Oct 29, 2007 | Toshiba 46HM95 46" HDTV
We have sound, but no picture
could be the relay transistor or diode close to the relay in the power supply
Sep 29, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 46HM95 46" HDTV Logo
225 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
