Question about Carrier Heating & Cooling
Carrier 58mvp100-20 just but a new control board in and now I'm getting an error code 42 can anyone help
  • 2 more comments
  • sjbeck Dec 05, 2008
    nope it didn't work
  • sjbeck Dec 06, 2008
    the yellow blinks 4 times then the green blinks 2 I read something about an inducer
    The 2 opinions I have received have not worked.
    I need some more help.
    I do wish to Thank Everyone who responded for their help but I found that there is a burned out circuit board on the induction motor
    sjbeck
    Genius:
  • 1,239 Answers
HI
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine..
Posted on Dec 06, 2008
  • 1 more comment
  • ABHISHEK.C
    ABHISHEK.C Dec 06, 2008
     E1 code indicates an internal electrical problem.I THINK some error code usually means that in the control board   a button is pushed in. The suggested fix was to "play around with the buttons and see if they unstick.
  • ABHISHEK.C
    i think yhe control board may be fried up
  • ABHISHEK.C
    a fixya rating would be great helpfull
  • 365 Answers
Seen that you have changed the last control board.what was the problem to that.try to make use of the sites which give the error codes on different situations.i am very sorry i cant help you
  • JITHIN ANTONY Dec 14, 2008
    does the problem solved
  • 19,396 Answers
I could not find error code 42, let me know if the led blinks a number of times.
Check and follow instructions here
Posted on Dec 05, 2008
    Sergeant:
    Champion:
  • 291 Answers
Disconnect the board and reconnect it ,,,, one of the pins isn't making / larry
  • Larry Youngblood
    Larry Youngblood Dec 05, 2008
    connect your old board and see if you get the same ,,, if not take your board back ,,, it must be bad
How do i fix error code 42 on my cellphone? Help! Ive tried everything!
How to Repair Error Code 42 ' Windows Error Support - Error Tools
errortools.com/en/drivers/how-to-repair-error-code-42/
  1. Cached
  2. Similar
Code 42 Error is referred to as a Device Manager Error code. Before we explain what this code indicates, it is important to understand what 'Device Manager' is and its functions. Device Manager is basically a Windows tool that helps manage devices attached to the system such as the Printer, Scanner and the USB Device.
Error codes in Device Manager in Windows - Microsoft Support
https://support.microsoft.com/en-ca/help/.../error-codes-in-device-manager-in-windo...
  1. Cached
Lists the error codes that may be reported by Device Manager and the possible resolutions in Windows. ... Manager. If you are getting an error code that isn't listed here, you can contact the hardware device vendor's technical support or Microsoft Support for help. ..... Code 42 "Windows cannot load the device driver... (Code ...
ERROR CODE 42 - Boost Mobile Community
https://community.boost.com.au/t5/Setup-Phone-Support/ERROR-CODE-42/.../20989
  1. Cached
Sep 3, 2017 - 1 post Help! I can't send or receive text messages! It keeps saying: Error code 42 I can't call or receive calls either and I know that my bill isn't due.
Instructions To Fix Windows Error Code 42 - Error.info
https://www.error.info/windows/bus-driver-42.html
  1. Cached
  2. Similar
About the Error. The Windows error code 42 indicates the fact that the operating system has detected a duplicate device. This is usually caused by a sub-process that the system accidentally named incorrectly. Windows code 42 - Read what really helps. Though Windows error code can sound quite intimidating, fixing the ...
Dec 14, 2017 | Cell Phones
Tip
CARRIER WINDOW ELECTRONIC CONTROL
CONTROL PANEL ERROR CODE
PROBLEM
REMEDY
E4
Thermistor problem
Shutdown unit and restart
E3
Unrecoverable of E2RAM data
Shutdown and unit and restart
E2
Loss or corruption of stored data
Using remote control go to Cool mode and shutdown the system, and then restart.
E1
Code validation check fail
Shutdown and unit and restart.
FL
Filter check warning
Press the “MODE” and (DOWN) “▼” buttons together until error code disappear.
Note: If the problem persist replacement of control board is needed.
-Push arrow up and arrow down together for 5sec. the room temp. will show.
on Mar 02, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
I just installed a Carrier Mini-Split and am getting an E2 error code. I have already replaced both boards in the outdoor unit IMP and Main PC with no luck. Any suggestions?
This is a Zero crossing detection error. This is alarm signal when the main chip can't detect over zero signal. When such failure occurs, the main control board must have fault.
Nov 02, 2015 | Carrier Heating & Cooling
A Carrier mod # 24ANA760A300 Infinity with an error code #72 high stage thermal cutout, What causes this?
if it's a thermal cutout that's mounted on the circuit board you may have to replace the whole board. I don't have the carrier error codes at hand. But a "thermal cutout" is normally found on the compressor. One advantage of the old (before digital) systems is that the controls were all separate. So you could replace a bad high pressure switch or contactor. Without having to replace a expensive circuit board that held most of the controls.
Not to mention being easy to damage by power surges and lightning
Jul 11, 2012 | Carrier Heating & Cooling
Carrier error 42 on model 58MVP080.... is it the inducer motor or control board?
Low pressure sensor fault. Check dc voltage between white and black cable on plug. Multi V: 1 Vdc = 4 bar up to 5 Vdc = 32 bar
Oct 19, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dell 944 error message 1102 after fitting new DellBlack Cartridge
hi there,
you can try these steps:
try to remove the new black cartridge. get a clean cloth. gently wipe the copper strip of the cartridge. unplug the power cable of the printer. gently wipe the contacts of the black cartridge carrier (where you put the black cartridge in). close the carrier, plug the power cable back in. install the black cartridge. then check for the error code.
if you still have same error code, try the old cartridge.
if the old cartridge still works, you need to contact dell for the replacement of the black cartridge (if you purchase the black cartridge from dell)
if the old cartridge is also giving same error. try the steps on the color cartridge as well, it might be with the color cartridge error.
or both.
worst case scenario the contacts on the printer carrier might be broken already.
but in this kind of situation. 98% it's the cartridge that's causing the issue.
have a great day :)
Oct 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
I have a Carrier Weathermaker SXi. Furnance will not turn on. I shut power off and waited ten minutes and tried to restart. Codes flashing are 12, 31, 32, 33, 41, 42. Can this be started in emergency mode?
Emergency heat is made for this kind of situation.So yes you can.
now for the codes.
code 12= Blower on after power up
code 31=High heat pressure switch or relay didn't close or reopened
code 32=Low heat pressure switch or relay didn't close or reopened
code 33=limit circuit fault(Flame rollout switch is open)
code 41=board fault
code 42=control lockout
Please rate this solution
Jan 17, 2009 | Heating & Cooling
Emerson Jumbo Universal Remote, Need code for 42" Polaroid TV
Olevia 237V HDTV will not tune in 50-1 using antenna any more
Dec 27, 2008 | Directed 434MHZ Remote Control
Color background, and then C255X error code (x depends of the color imaging unit)
Those codes are related to an abnormal toner to carrier ratio. If you are getting multiple errors that could be a control board failure. I will consult Konica Minolta Solutions and post futher as the information becomes available.
Jan 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Heating & Cooling Logo
391 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
