I need the operating instructions for teh 00963MH sound card. Ken Widelitz
Computer screen has lines and colours wrong had a blue screen withfile nv4-disp. i try to update the graphics card driver but it just comes back with the error on reboot the device driver got stuck in an...
The driver is the issue ..If the card would not work anymore you would have nothing on screen ..The fact that the colors are strange and image does not keep the resolution it means the computer runs without the graphic driver and you need to reinstall it .If you still have the driver cd from the manufacturer of the card ..you can load it again and run it from there .If you have an onboard card ..the driver should be on teh cd with drivers for the motherboard ..along with the other devices ..sound lan ..etc ..
In the case you do not have teh driver anymore and it is a brand computer ..look on the manufacturer site and search by the model and operation system and download it and install it..If it is a generic computer ..and the graphic card is a agp or pci one ..installed separately ..look on the site of the card's manufacturer..and download the driver again .. If you can not manage and you know what is teh card name ..let me know and i link the driver in a comment ..
have a nice day ..and please do not forget to rate my answer..
Dec 19, 2011 | Computers & Internet
I can't browse internet using my samsung r519 laptop
Usually if the browser do not display the engine or home page , to blame is the internet connection . Depending on what kinda connection you use...check the cards for to be installed proper . To do that open the device manager and look for the network cards..and be sure they do not appear in the list with yellow marks ..If they do ..you need to run again the drivers for them or for the one is missing .
If you do have all drivers..and you use a wireless connection ...be sure you have one ..and the card is enabled..for to enable teh card just press the wireless button and when it is lit it will display the connection ..and you need to open it and scan for networks choose yours and connect .
If you want to get to the device manager just click right on computer icon ..choose properties and (hardware ) device manager ..
If you need teh drivers insert the disk you got from teh manufacturer.the one with the drivers and if you do not have them ..just go to teh support page ..select the model and download them again (also select operation system ) .
have a nice day !
Nov 21, 2011 | Samsung Computers & Internet
Sound system not working on dell vostro 1015
Usually sound problems are related with the driver ..so ..first thing to do if you think you tried all rest ..is to reinstall the driver for sound card ..to be sure you have teh correct driver ..sownload it from teh support site of the manufacturer ..and select teh exact ,model ..and operation system, you have in the laptop ..Download the driver and run it to install ..all the way ..until asks to restart ..restart it ..and it should work if the card is not damaged..
here are all the drivers for your model ..It is selected for windows xp ..but all you have to do is to select other operation system and download ..
http://www.dell.com/support/drivers/us/en/19
If you run windows xp and it originally come with Vista on it ..I think you may need to run the UAA architect driver first ..and after that the audio driver ..cause for the conexant audio driver ..It may be needed..It will basically not see the audio card in xp without it ..
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Microsoft-UAA-Bus-Driver-for-High-Definition-Audio.shtml
its a Microsoft bus driver for HD ..
Oct 10, 2011 | Acer Aspire 3050-1733 Notebook
I have the tv card installed I have video but no sound is this a common issue
no is not a common issu e...probably you do not activate the sound ..or it is on mute ..or windows is not seeing the card like it should...Also check on the sound card properties..and see under optiond ..properties..if the tunner is activated ...Just double click on the sound icon in the task bar ..and on the volume control ..click on options ..and properties and tick the case for teh tuner ..
Also check into the tuner's operative program ...if it has options for the sound...and choose the default ..or the card you have in use..(check volumes..and the mute option
Jun 26, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
How to install sound card
Hi there... If your computer is a desktop, open the side panel and insert the sound card in one of the pci slots on the motherboard. Then turn teh computer on and insert the cd installer that came with the sound card. Hope it is compatible with your operating system.
Have a great day!
^_^
Jun 04, 2010 | Compaq Audio card Sound Card
Sound quite working on my dell inspiron 5305
hi.... if quite = stoped , then we might have a solution :)
u might have a pci sound card or a build in one, any way you need teh driver, and its in a special disk(if its a pci sound card), or the disk that came with your pc......so go to device management, delete all the drivers...and if u have any other software related like (realtek......) delete it to.....restart...and whene u willl be asked questions, putt on the disk and folow the instruction,,,,,,gd luck
Oct 24, 2009 | Dell Inspiron 530s Desktop Computer...
My HP laptop crashed, I reinstalled the origal disk but I havr no sound. The error message is no sound card installed. What happened to my sound? and how can I get it back? ...
You need to install the sound drivers for the particular model of laptop. I need to know your specific model of laptop to help you further.
Sometimes the drivers for certain hardware are not included on the Windows Operating System Installation Disk and come on a separate driver disk.
If you do not have a separate disc the drivers can usually be found online.
Sep 16, 2008 | Microsoft Computers & Internet
Operating instructions
the em switch is back up heat
Jan 30, 2008 | Heating & Cooling
Sound
Your sound card driver needs to be reinstalled. Do you have teh original disc's that came with that computer? If so I can walk you throught it.
Sep 17, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
