Question about Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246)
How do I navigate from pc to pc with a Intellenet switch?
I need to know how to get from pc to pc. I have 4 pc's on this switch.
  • 340 Answers
Hi Barvic, and welcome to FixYa,
do you want to "administer" the 3 pcs from the 4th.?
There is a very good program called TeamViewer, download the free version from here:
/Teis - > do vote
Posted on Dec 06, 2008
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
How to delecte recent logs
These steps should be more or less similar.
  • Press the OK button for Menu
  • Select Recent Calls, using the navigation keys
  • Select All (4)
  • Select the Recent Call type, using the navigation keys, from the following:
  • Missed Calls
  • Received Calls
  • Dialed Calls
  • All Calls
  • Highlight desired Recent Call, using the navigation keys
  • Press the right soft for Options
  • Select either Erase (2) or Erase All (4), using the navigation keys
  • Highlight Yes, using the navigation keys
  • Press the OK button to confirm call log deletion
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 22, 2011 | Samsung SGH-T309 Cellular Phone
Need to know the location of suspension switch to 2006 lincoln navigator.
The air bag suspension switch is located in the front passenger kick pannel. Use a light and get down where the front passengers feet go you will see a little red switch farther forward on the right hand side against the outside pannel.
Dec 06, 2010 | 2006 Lincoln Navigator
My 1998 navigator 4 wheel drive got stuck& now ac wont work
2 different electrical circut's that are unrelated. Ac on a 12 year old truck is bound to need some service. Take it to a trusted shop that is not hurting for work & ask them if anything is disconnected, ie: compressor power wire, high pressure switch...ect. Tell tale sign system is low on freon is the compressor keeps cycling on & off with a clicking sound or compressor does not come on at all.
Mar 20, 2010 | 1998 Lincoln Navigator
Need to transfer files to mac
You can follow this steps for your concern: Via Memory Card 1. Remove the memory card slot cover, located on the right side of the unit. 2. Insert a microSD memory card into the memory card slot until it locks in place 2. On the SGH-i607, navigate to the folder that contains the image 3. Highlight the desired image 4. Press the right soft key for Menu 5. Select Edit (4) 6. Select Copy (2) 7. Navigate to the Storage Card using the up or down navigation keys. 8. Press the left soft key for copy the image to the memory card Via Bluetooth On the SGH-i607 1. While in standby mode, turn Bluetooth on 2. Switch the Bluetooth visibility to On On the PC 1. Connect the Bluetooth adaptor to the PC?s USB port 2. Search for Bluetooth devices 3. Select the device to pair with the PC 4. Exchange PIN code(s) on both the PC & handset to pair devices (default pass code is ?0000?) 5. Using My Bluetooth Places, select File Transfer or OBEX to view the phone?s contents 6. Copy the desired Photo file 7. Paste the file in a PC destination
Feb 02, 2010 | Samsung Blackjack SGH-I607 Smartphone
Diagram 2000 lincoln navigator 5.4 firing order
My apologies for the delayed response.
I am going back to answer - unanswered questions. I have only been on this site for the past 4-months. Questions Posted have exploded (+55%) since joining.
I do not know if you still need this information, but I am answering it either way.
For the 5.4L:
Firing Order:
(back of engine)
(front of engine)
Again my sincerest apologies....
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at!
Oct 07, 2009 | 2000 Lincoln Navigator
Need to locate gas switch lincoln navigator 2001
If you are talking about the fuel cutoff switch they are generally located in the rear of the vehicle. Look in the cargo area on the driver side behind a panel. I know on these with the air ride system the switch for the air ride is under the dash on the passenger side you can check here also for the fuel switch, but generally they are in the rear of the vehicle.
Sep 20, 2009 | 2001 Lincoln Navigator
I have got a myguide 3100 and it has worked well
You need the UPDATE package 4 your mygudie 3100.
4 solution contact me
Aug 31, 2009 | MyGuide 3100 GPS Receiver
"write protected" flash drive no switch or anything to take it off
Your computer probably has a registry key set to make your flash drive protected.
To remove this follow the following directions:
DISCLAIMER: If you are not comfortable using the registry editor find someone who knows how to and is comfortable using it.
1. Open Registry Editor Start-->Run Type: regedit
2. navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
3. Click on "StorageDevicePolicies"
4. Double click on Write Protection and change value to '0'
5. Repeat for CurrentControlSet001 002 etc. etc.
6. Restart
7. Test
Hope this helps
Have a great day!
Jan 25, 2009 | Computers & Internet
2003 Navigator Air Compressor
your truck needs transmission fluid asap,this happened to me to.after the fluids went in........problem solved !
Jan 06, 2009 | 2003 Lincoln Navigator
Ball joints for a 200 Lincoln Navigator
if you need this info you should not attempt this yourself. it takes special tools and can be dangerous doing this and not knowing what not to do.also if you get it done and its not correctly done it could cause a accident hurting you or your family or others. i recomend this job be done by the pros. good luck. sorry if you did not want to hear this.
Jun 24, 2008 | 2000 Lincoln Navigator
Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246) Logo
52 people viewed this question
Top Intellinet Active Networking Computers & Internet Experts
Prashant M
Prashant M
Tech support
Tech support
Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
