Question about Seagate Barracuda 7200.7 80 GB Hard Drive
Capacity I was formating my Hard drive and i had it in single partition... Now when it was finish i found out that it was half of the full disk capacity which is 80gb. Can anyone reverse this because i tried formatting it and keep on giving me the same 31.42gb capacity.
  • donnie_rife2 Oct 28, 2008
    i have a seagate 250 gb hard drive and can't get the full capacity,only 127 gb,no help when i used disc wizard or partion magic
  • 247 Answers
Pre 1999 machine with Award BIOS? If so, this is because when they designed your computer, they didn't imagine 80 GB drives were a realistic prospect. Suggest you download DiskWizard from Seagate's website and use that instead of Windows to format the disk. Hopefully this will be enough to let you see the full capacity of the disk. A.
Posted on Feb 13, 2007
Tecra A11 can't see all of 3TB drive
Support for Disk Drives Beyond 2.2 TeraBytes (TB) and 4K Advanced Format Sectors
Most legacy systems built before 2011 have a traditional PC BIOS. This type of BIOS uses a Master Boot Record (MBR). The MBR Partitions can define a disk drive capacity up to 2.2TB. Windows operating systems that boot from an MBR are therefore limited to 2.2TB per MBR. A 3TB disk drive in a legacy BIOS and Window system will need a DiscWizard device driver to access the full capacity of a 3TB disk drive. Two partitions will be necessary because of the MBR limitation. The device driver mounts the capacity above 2.2TB with another MBR which looks to the system as a second virtual "physical" device.
GUID Partition Tables (GPT) can define drives larger than 2.2TB. You can use GPT today on any Windows 10/ 8.1/8/7 and Vista system as a non-booting data drive. Windows can only boot a GPT partition on a new type of BIOS called UEFI.
UEFI BIOS desktop systems are new since 2011. Windows 10/8/8.1/7 64-bit and Vista 64-bit operating systems support booting from UEFI and GPT without the need of a non-Microsoft device driver. This is the Windows native solution for booting a 3TB drive to a single partition.
Quick facts about Windows and 3TB drives:
  • Windows 10/8/8.1/7 and Vista support GPT 3TB single partitions
  • Windows 10/8/8.1/7 and Vista can only boot GPT on systems with UEFI BIOS
  • Windows 10/8/8.1/7 and Vista can mount a GPT non-booting data drive
  • Intel RST device drivers before v10.1 do not support 3TB disk drives
  • Windows systems with Legacy BIOS and MBR boot drives are limited to 2.2TB partitions
  • Windows XP does not support GPT
  • Windows XP sees a 3TB drive as 800GB on boot or data drives
  • DiscWizard software can install a device driver which opens the full capacity of a 3TB. You can use it to create a second partition for the capacity above 2.2TB
Sep 27, 2017 | Toshiba Computers & Internet
Wd drive PATA wdc-wd2000 jb - 00fua0 should be a 200 gb drive. said was running out of space and when checked found drive was only reporting it's size as 31.49gb. have tried everything I can think of to...
Check the hard drive for partitions, it could have several partitions, but only the first partition has been formatted.
Go to Control Panel - Administrative Tools - Computer Management - click on Disk Management and look at the Western Digital it could be Disk 1.
If you see unallocated partition, you can create and format this partition.
OR
You can delete the existing partition and create a single large partition and then format this partition.
NOTE - this process will delete the existing data on the hard drive.
Dec 16, 2010 | Western Digital (WD2000BB) 200 GB Hard...
If I try and format my LaCie drive through my computer its capacity shows as 9.99 MB why is that if I do format it (NTFS) will it have the correct capacity of 250G
You may have two or more partitions on this hard drive. If you delete all the partitions and then format the hard drive then you will have the full unformatted 250 Gb capacity.
Sep 24, 2010 | LaCie (300770) 250 GB Hard Drive
Can not format my samsung hard drive with DOS command and Disk Genius and lost 49 GB capacity. What can I do?
You may have the hard drive partitioned into two or more partitions.
Delete all the partitions and create a single partition and then format this single partition on the hard drive.
Mar 14, 2010 | Samsung (SP0822N) 80 GB Hard Drive
80gigs partition then reformatted and displays only 31gigs
If there are files on the drive that you need to recover, then do not format it. It sounds as though the computer that you put the drive into has an issue where the bios perhaps does recognize the drive correctly. Perhaps that can be corrected by updating the bios in the computer, and trying the drive again. Or you may want to put it back into the original computer, back up the files to other media, and then put the drive in the computer and re-partition.
What does the FDISK - "DISPLAY PARTITION INFORMATION" utility report? Do you have a copy of FDISK? If the partitoins in FDISK add up correctly, then it could just be that the data is corrupt, and windows is just unable to read. If that's the case, you should try a recovery application to restore your data..
Nov 15, 2009 | Dell Tablets & eReaders
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
I need to dump all the information on my Maxtor.
You will need to format all the partitions on the disk to make free space. This will erase all of your data, so you will be able to use your disk at full capacity.
You can format your partitions via Windows Explorer, just right-click a partition and choose Format....
Be aware that if you format a system partition you will have to reinstall operating system.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Maxtor Hard Drive
What to do with unreadable but recognised hard disk segate 400GB
Your Windows Xp bootable CD should have an option called "Format his file system using FAT32" while installing the OS. Use the option to format it. The only prob is that it creates only a single partiotion. After installing windows you can re-partition using a third party software such as Partition Magic(please note that it will not affect your windows installation as you can first re-size the windows drive to a lower capacity and then partition the un-allocated space.
Nov 29, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Formatted a WD500GB hard drive with windows xp using the fat32 format. the disk space shows only 1.99GB FREE HOW CAN I GET THE DISK TO BE THE FULL CAPACITY MINUS THE OPERATING SYSTEM, ...
Creating and formatting a new partition:
  1. In the lower windowpane on the right hand side, you should see unallocated space for the drive. Right-click anywhere on the unallocated space to see a menu of available options.
  2. Click on Create Partition
  3. The Create Partition Wizard will appear. Click on Next.
  4. Leave Primary partition selected and click Next.
  5. Choose the partition size and click Next.
  6. Leave Assign a drive letter. selected and click Next.
  7. Leave Format this partition with the following settings: selected and choose the file system you want. Select Perform a quick format and click Next.
  8. Click Finish.
  9. Under the drive it will indicate that the drive is formatting and will show you a percentage complete. Depending on the size of your hard drive and the speed of your computer, it could take more than an hour to format the whole drive.
Oct 19, 2008 | Computers & Internet
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Seagate Barracuda 7200.7 80 GB Hard Drive Logo
81 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
