Question about HHP ImageTeam 3800LT (3800ltp-12) Handheld
Imageteam IT3800 scanner won't hold the config.
Hi! WHen I configure the scanner it loses the config right away. I configured several devices the same way and verified what I was doing by using a known good scanner. see text below... Plugged the scanner into a COM port on my PC Scanned the RS-232 barcode (this tells the scanner to use RS-232 communication) Successfully connected to the scanner via the Visual Menu software (this is the scanner configuration tool) Uploaded the scanner configuration via the software?this is where the problem occurs The configuration is written to the scanner successfully, but After writing the configuration, the software is not able to again connect to the scanner and in order to proceed, it is necessary to start back at step
    Scholar:
  • 121 Answers
Does the scanner use a small battery to keep the stored information? If it does, this battery might be defective.
Posted on Mar 09, 2007
Remove last digit on a it3800
You should try downloading the configuration manual from Honeywellaidc, it should probably be there still.
When you have the setup book, search for data transmision options.
Apr 14, 2014 | HHP IT3800 Handheld
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
Hello, Can you please tell me if you can configure the HHP Handhel Scanner to NOT beep on a unsuccessful scan? Currently our scanners do deep on a unsucessful scan. Can you also tell me if we need to...
Maybe there is a code configuration for this. Plese check the user's guide: http://www.geoti.co.kr/DATA/hhp/IT3800_3900%20Users%20Guide.pdf
Hope it helps!
Jan 16, 2011 | HHP IT3800 Handheld
My cisco 4503 keeps losing it's configuration file.. any ideas why this is happening? thx.
The case gives me hints towards the configuration register value which is not set to proper value, so the switch is not checking the the saved configuration in the config file.
Please do the below steps.
1. Log into the switch
2. Come to enable prompt
3. Typein the below commands
config t
config-register 0x2142
end
write memory
The find an example of the prompt and the commands below
Switch# config t
Enter configuration commands, one per line. End with CNTRL/Z.
Switch(config)#config-register 0x2142
Switch(config)#end
Switch#write memory
After this you can configure your switch as per your requirement and then save the config by typing write memory
Now you can reboot your switch and the switch will come up with the configuration as you set.
Best Regards
Nov 06, 2010 | Cisco Catalyst 4503 (WS-C4503) 12x1000...
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
HHP Handheld IT3800lr-12 - i can't configure it to USB
If you have the manual, try to cofigure it to USB Keyboard and/or to LAPTOP DIRECT CONNECT. This last option is on page 1-7 in the manual I have with me. Please let me know if it works... Good luck!
Dec 15, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
HHP IT3800 scanner will not run as Power User only with Admin rights on XP Pro
You may be able to resolve this if you allow power users modify access etc to the the installation folder of the HHP scanner software.
This needs to be done as an administrator.
This can be done by opening explorer and going to the root folder of the software. Firstly you need to ensure that simple file sharing is disabled - to do this go to tools - folder options and click on the view tab. Scroll all the way to the bottom and uncheck enable simple sharing. Click ok. Now right click on the folder go to the sharing and security option in the popup menu. Click on the security tab and click on ADD. Type in power users in the input field and click ok. In the permissions area enable modify and write access.
This should fix the problem.
Apr 24, 2008 | HHP IMAGETEAM 3800LR Handheld
Problem with scanner
I have it connected to keyboard port as they instructed.
Sep 02, 2007 | HHP 3800 (015305) Handheld
Bar code reader problem
In the user manual for this device there should be a code book (or code pages), These are a selection of barcodes which you use to configure the device. One of the settings is to omit the barcode header (which indicates a type of barcode for instance a PART number might begin with P or a Serial number might begin with an S) This barcode system may have been initially programmed to omit these code letters Gareth
Jul 04, 2007 | HHP IT3800 Handheld
It3800 barcode scanner problems
Will it scan data into excel or word?
May 21, 2007 | HHP IT3800 Handheld
HHP ImageTeam 3800LT (3800ltp-12) Handheld Logo
538 people viewed this question
Top HHP Computers & Internet Experts
Marvin
Marvin
gggg
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
