Question about HP Office Equipment & Supplies
I am trying to install a new HP Printer C4345 and in order to do so I was advised I had to remove all of the HP 1500 elements. It will not remove HP Image Zone Express when I tell it to remove it. The system says wait on the system to remove it, bit nothing happens. Does this have to be removed to install the new printer.
    Scholar:
  • 68 Answers
That software doesn't necessarily have to be removed for the new printer to work, but it could cause some conflicts down the road. I would recommend that you completely uninstall the printer (Control Panel -> Printers) and that you remove the printer in the Device Manager if it is still there. Then follow the instructions and install the new printer.
Good Luck!
Posted on Dec 05, 2008
Is it possible to check ink levels on an HP C4345 All-In-One Printer/Fax. I use Windows 7. Have gone into Properties, etc w/no luck. Thank you.
First, I would try printing a document, and a window should pop up in the lower right corner. If not, make sure that you have all the necessary drivers for the printer installed, as that is the only way to check your ink levels with the HP C4345 All-in-One Printer. In my experience, you must use new HP printer cartridges (rather than ink refills) to have an accurate reading of the remaining ink.
Aug 11, 2011 | HP PhotoSmart C4345 AllInOne InkJet...
My printer HP Officejet J4580 All in one, does not print, It reports "Entering sleep mode". Put new ink cartriges in, paper not jammed and no lights flashing and I printed a test page on the printer to...
Hi.
Try the following in order:
Disconnect printer power cord.
Turn off computer.
Disconnect computer power cord. (if laptop also remove battery)
Restart first computer than printer.
(this may look stupid, but it drains power that can jam USB ports and cause malfunction).
Clean the metal plate contacts in the ink carriage using cotton and isopropyl alcohol or cleaning solution.
Try turning off printer and performing a new cartridge installation. Use the HP software cartridge replacement procedure, do not simply swap cartridges.
Disconnect printer USB, reinstall printer software, connect printer back when prompted by setup wizard. Updated software for this model available at Software & Driver Downloads.
If you have spare cartridges, test them, the problem may be caused by a defective cartridge chip. Non original or refurbished cartridges commonly cause similar problems.
Sep 14, 2010 | HP Office Equipment & Supplies
I have HP printer C4280 All-in-One my paper got jammed
Just press the Power button once. While the printer is Powered ON.
It will try to throw out the Jammed Paper.
Then remove the Power cable from the back of the printer.
Open the Real Door and try to take out the Paper stuck in there. Manually clean the rollers with a lint free cloth.
Jun 02, 2010 | HP PhotoSmart C4345 AllInOne InkJet...
Need to install printer HP PSC 1500 all-in- One series
i lost the software of psc 1500 all-in-one can you help me?
Jun 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
Whirlpool bake element 9758541 installation assistance.
make sure power is off take the 2 screws off element holder inside oven remove 2 screws on element reinstall
Nov 27, 2007 | Kitchen Ranges
29 people viewed this question
Ben Johnson
