I switch on the printer gto through the operations. Press the start button. In starts first operation, aq sort of click. Then nothing further un til the paper comes out blank
  • rbuckingham4 Dec 06, 2008
    Everythng is o.k. now
As a learner I forgot to click PRINT. I am 89. It takes time. Thanks anyway
Posted on Dec 06, 2008
I keep getting this error Operator error. Press the printer's RESUME button. If this doesn't clear the error, cancel printing and turn the printer off and then on again.
Go to start... control panel
look for printer and devices or something of that sort till you find your printer model.
Double click on the printer... you should see a doucument queue that is waiting to be printed...
Right click on all pending jobs and say cancel or delete....
Jul 25, 2010 | Canon BubleJet i965 InkJet Printer
The print is hardly visible and the ink cartrige is almost full
press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Jul 19, 2010 | Dell 922 All-In-One InkJet Printer
Will photo copy and fax but will not scan - ask to check the cable
Hello, kristen482
Sometimes what happens is that the software installed on your computer, relating to the printer will become sort of confused. Re-install the software after a quick un-install of the same software. You can get the software from either a disc or from the Web Site of the printer's manufacturer.
Sometimes updating the USB Drivers will be needed. Do that by visiting the maker of your computer and search for Drivers and Updates on their Web Site, look for 2.0 USB drivers class, download that package to your desktop. The driver might be in the form of a Zip FIle. In that case, unzip the files using standard WinZip program or use software provided by computer, to a folder called cab. The driver program might show preference were it wants to unzip to. If so, let it do its thing. Then afterwards find the folder (cab or other folder) run USB driver by clicking install exe file. Note that all peripials need to be unconnected from all USB ports ( the port the laser printer connects to the computer at ) before updating USB drivers. So check cables for solid reconnecti0on after installing drivers.
After doing this update, an reconnecting the power and USB cables. Check the operation of the scanner table itself.
Verify that there is nothing wrong with the light bulb belonging to the scanner table. To do this have the cover up of the scanner and press scan button, the program should initialized on your desktop, the the light should turn on and after a few seconds (or more) should start moving across the table.
Contact Brother Web site for further advice if this operation doen't occur and the steps fail. But generally this is the basic troubleshooting to insure the software and the all in one are working properly.
Good luck, jasahasch
Aug 13, 2009 | Brother MFC-7820N Laser Printer
Scanning
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&lang=en&product=90792
Issue When the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
Oct 04, 2008 | HP Officejet 4110 All-In-One InkJet...
Ink absober full
Service - mode in which you can perform service operations with the buttons printer. To switch the printer Canon MP-series in the “Service” mode you:
1) Turn off the printer.
2) Press and hold the button lifting / resume printing.
3) Press and hold the button printer.
4) Release the button lifting / resume printing.
5) Double-click restoration / print.
6) Release button printer.
after that time will be flashing green LED (flashing time depends on the printer model), then it will go steadily and the printer will become the “Service” mode.
Low-Level - work intended for low-level operations with EEPROM printer, in this mode MPTool works with the printer. To switch the printer MP-Series Low-Level regime should:
1) Turn off the printer on the network.
2) Press and hold the button.
3) Add a printer to a network.
4) Click lifting / resume printing.
5) Release button.
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
Jun 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
I have a hp pavillion mx703 computer and a Lexmark Z705 printer. They have been working fine together till about a week ago. Now my computor does not recognize that I have a printer. I have tried to...
Hi gig14789,
Never do a re-install unless you run the un-install software or remove the program from within add/remove programs in control panel. You're software is all messed up now. Lets try this.
Turn off you're printer (press the on/off button). Click the start button & slide up to & click on control panel. Once opened. Double left click add/remove icon & it will open. Find Lexmark & un-install the software by clicking on remove. Un-install/remove anything having t do with the Lexmark printer. When finished close all opened windows. Restart you're system. When windows has finished loading I need you to creat a folder on you're desktop. Name it (Lexmark Z705). Click on the link below.
http://search.lexmark.com/printer/US/en/15L0000
Save this link above to you're favorites. (You may need to come here again).
Scroll down the page till you see, Lexmark Z705 - Drivers and Downloads. Click on you're operating system.
Click download now. Choose to save the file. Save the file into the folder you created (Lexmark Z705). Once down loaded open the (Lexmark Z705) folder. Double left click the .exe file.
Follow the instruction & on screen prompts. The software will tell you when to power on you're printer.
If this fails to install correctly please post back in this windows & list any error messages you might receive. List you're operating system too.
Good Luck!
Mike
May 06, 2008 | Computers & Internet
Printing
Trying this fix from the Lexmark X63.
On the printer itself.
Hit the "setup" button.
Press "menu" 'til the maintenance appears.
Press "options" 'til cartridge clean appears.
Press "start"
or you can do it from your computer.
start, programs, lexmark print control panel.
Click cartridges tab.
Then select clean print nozzles.
Apr 03, 2008 | Lexmark X73 All-In-One InkJet Printer
Scanner?
In the first case If the Printer makes copy...fine.
Then the Digital Monitor is not running in start up.
By clicking on hpqtra08.exe under \Programfiles>hp>digital imaging>bin. will help it Other wise Un-install / re-install software......But ther should not be any other hp All-in-one software.
In the second case is driver conflict: By in-install the other version of image zone will help it & make sure the digital monitor is running in system Tray,
Let me know the operating system as well.
Nov 28, 2007 | HP PSC 1210 All-In-One InkJet Printer
Ink cartrige wont work
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
41 people viewed this question
k24674
