Question about Kenmore 62882 Electric Dryer
Kenmore basic model dryer
We have a Kenmore basic model dryer. The model number is very long and unfortunately I do not have that number with me. I think that my problem will be asily answered without the serial number. The problem is that I turned it on and it ran for about 10 minutes and then it shut off. I tried to turn it back on and it would not start. I let it cool off and then started it again. I looked down the back of the dryer and a part in there is glowing red hot. So much that I could see it without taking the back off. Needless to say I have turned it off and left it off since seeing the glow. Is this the heating element burning up? Is there anything we can do to fix this problem ourselves? What will prevent this from happening again? I clean the lint trap before every use and maintain as best as I know how.
  • Anonymous Oct 22, 2008
    Kenmore Heavy Duty: mod:96260100. Very basic: set timer,push on. Can't find any help.Starts/runs 4-5mins,gets hot then shuts down.Cools down,same song.Single dad,2 girls,must do laundry! Removed top,vaccumed out,check connections.Cleaned duct,vent etc.Same result. Thermocoupler? if so,where is it?Thank you in advance.Timothy
    President:
  • 878 Answers
JaJa, outside of the excellent advice that was posted by jsrock, it sounds like your element is shorted to ground. It could be a bra-wire or something else shorting it. If your model is similiar to the posted dryer, you will have to remove the back panel. The heating element will be on the right side. There will be 2 quarter inch screws holding it in the duct. Remove these screws and the heater will pull down. Sometimes they are in there tight so it might take a little. See if you have something in there shorting the element. Make sure to have the dryer unplugged while going in there. This is not that hard of a gig. Catriver..post back.
Posted on Apr 29, 2007
  • 5,911 Answers
The glowing you are seeing from inside the dryer SHOULD be the heating element. However, if your heating element is glowing as bright as the sun, this is an indication of improper air flow. This can be attributed to clogged ducting. In order for your dryer to dry properly it needs proper air flow through the drum and out through the ducting. A few things you can check: 1. Are your clothes taking longer to dry? 2. Is there proper air flow coming out of the ducting exhaust? 3. Is there lint backing up inside the dryer and/or in the room that the dryer is sitting? 4. Is the outside ducting clogged? 5. Is the dryer getting extremely hot? If you can answer "yes" to any of these questions, you need to replace your ducting and/or have it professionally cleaned. If your dryer is turning off it's usually a sign of overheating. Eventually, the thermal fuse will blow or the heating element will burn out. In both cases, parts will be required to fix. A little routine dryer cleaning will go a long way towards keeping it running longer and preventing the need for repairs. I hope this will help you.
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Clothes are melting in my dryer
Hello Thelma;
My name is Peter. I am a retired field service appliance technician.
Good for you changing the fuse. More and more women are becoming handy with repairs.
Unfortunately, the fuse blew because of another problem.
You may have a high temperature limit switch problem. You may have a time cycle problem.
This is a hard question to answer since you did not provide a model number for me to see what dryer you have.
Please submit your question with the model number. Open the dryer door the model number is on a label inside the door.
Nov 30, 2014 | Kenmore Dryers
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
My dryer wont get hot . think the pilot is out . .. how do i relight the pilot
send the model number,you can't light the pilot anymore,they are electronic ignition now,is it gas or electric?find the model number around the opening where you put the clothes into dryer
May 08, 2010 | Kenmore Dryers
I have a Kenmore dryer that is 4 years old, very basic model, and it heats only part of the time. At times when it is running there is a gas smell, no heat. Other times just the fan blows with no heat or...
The thermocouple may be going bad. The thermocouple is what "tells" the control unit that there is a flame. If it doesn't send it's signal, the control thinks the flame went out and shuts off the gas to prevent an explosion.
Jan 02, 2010 | Kenmore 73952 Gas Dryer
Hello,my kenmore dryer wont heat. i am not sure where the fuess are? thank you mike
There are no fuses internal to the dryer, except for a thermal fuse located with the strip heating element.
Let's start with the basics, does the motor turn the drum but the unit just does not heat?
Is this a gas or electric dryer?
Please provide Make and Model number of the dryer.
Dec 18, 2009 | Kenmore Washing Machines
What year is the 86870100 kenmore dryer
I think what you have is a 110.86870100 made by Whirlpool for Kenmore. Hard to tell the date from the serial number BUT.. there should be a mfg date somewhere on the back or maybe inside. If you are looking for a repair manual, try ebay or a general search on Google. Be sure to add the "110." to the model number when seraching... All I can say is that it's old..
Dec 12, 2009 | Kenmore 63942 Dryer
Kenmore 600 timer no longer works
This is not an easy task. you will need to disassemble the entire control panel to extract the bad or faulty timer. Extraction can be tough on some model. this will cause an inexperienced do it yourselfer to break off fragile retaining clips and screw anchors as well. you will also need to make sure that the wiring harness is re attached to the new replacement timer correctly. this is important. We recommend calling for service on all electrical repairs if you have minimal experience in this field of repair. Unfortunately , when these timers are damaged, you cannot repair them. you will need to replace the bad timer with a entirely new timer.
Jun 10, 2009 | Kenmore 600 6963 Electric Dryer
Want to stack my Kenmore HE4 Dryer on top of my Kenmore HE3t W/M
When you originally ordered the dryer, it should've come with a stacking kit that is compatible with the HE 3T or HE 4T washer. It is basically a foam piece that goes on each side of the washer, and then the dryer is connected to it from the side. If you do not have this piece, it should be available to order if you visit http://www.searspartsdirect.com Just enter the model number from your dryer (inside the door frame) and it should pull up a parts list. Or just try searching for a stacking kit for Kenmore dryer. Hope this helps.
May 18, 2009 | Kenmore Elite HE4 Electric Dryer
Need manuals
What problem are you having, the problems i have seen with kenmore elites are below.
1. when you press start and release dryer shuts off
for this problem, change the board in the console
2. not producing heat
for this problem, check to see if 220 is getting to element, check to see if you are getting 220 from outlet, check your thermal cutoff on heating housing, check your heater relay which is located in top console.
Apr 02, 2008 | Kenmore 63942 Dryer
Kenmore 62882 Electric Dryer Logo
91 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
